Paper Jamming on transfer Drum clc 1160
  • carlosramosdrum
    • Sep 2012
    • 45
    [Jamming] Paper Jamming on transfer Drum clc 1160
  • teckat
    • 16092
    Re: Paper Jamming on transfer Drum clc 1160
    too many things can go wrong with printer during a transportation move, if it is not prepared properly .
    I would first check all connectors on all boards< also remove covers & check connections on front of transfer drum.
    check the spring clutch on attraction roller unit end-
    the transfer / attraction / static hvt cable that mounts in the rear of the transfer drum assembly.
    The HVT cable inside the transfer drum may be arcing or intermittently open because the spade connector's on the end of the HVT lead may not be crimped tightly.//or just loose & not connected.
    When paper from the registration roller is put on the transfer drum sheet, the registration roller
    releasing solenoid (SL5) turns on, causing the registration locking cam to rotate and, at the same
    time, releasing the registration link roller from the registration roller by the drive of the main motor
    (M4).
    The copier’s transfer drum is designed to retain paper on the transfer drum sheet using static
    charges.
    During copying operation, the attraction roller solenoid (SL6) remains on for a period of time
    equal to the length of the paper to bring the attraction roller in contact with the transfer drum sheet.
    At this time, the attraction brush turns on, causing the transfer drum sheet to attract the paper.
    The transfer drum houses the attraction brush, transfer blade, and an internal brush for
    cleaning. Each brush or blade is away from the transfer drum sheet, and is brought against the
    transfer drum sheet by its respective locking cam when the attraction/transfer locking cam motor
    (PM7) turns on as needed.
    • carlosramosdrum
      • Sep 2012
      • 45
      Thank you for your help. until now i cannot fix it yer. you can see this video i made to know exactly the problem.
      any more help shoud be apreciaterd...
      Thank you
      • charm5496
        • 2387
        it could be several different things...
        Attraction and transfer brushes that are inside the transfer drum unit
        tranfer sheet is worn or has a film on it
        HVT connection from the transder drum is broken
        retention assembly is not pressing the paper on to the transfer sheet properly
        Have you tried any other stock paper than the one you are trying in the video?
        and what type of stock is that paper you are running there?
        • teckat
          • 16092
          Thank you
          ???? are u a tech. -
          did u follow any suggestions posted ?? search online for a free CLC1100 series manual/
          or call for help--
          it would take me 3 to 4 hrs to explain and describe conditions that can effect attraction issues
          • carlosramosdrum
            • Sep 2012
            • 45
            Hello.
            This is nothing Inside the transfer Drum. I tested al he transfer drum unit in another clc, 1150 machine, and it worked perfect. so atraction, transfer blade and trasfer drum plastic seems to be out of the problem. the problem is in the machine itself.... any more advise to continue my research???
            Thank You
            • charm5496
              • 2387
              at this point you could check the HVT wires running from the back of the machine to the connector where your transfer drum connects to the rear frame.
              you could have a timing issue with the paper reaching the transfer drum as well...this would include the registration rollers, retention assembly, clutches, paper guides and horizontal feed assembly.
              • teckat
                • 16092
                Hello.
                Thank You
                get a manual/
                there is a harness on transfer frame that needs checking(including black plastic connector)
                u need to remove transfer frame> get a flashlight>look inside of printer toward back>
                look to see if any torn paper bits are wedged inside the transfer frame machine side connector /
                • carlosramosdrum
                  • Sep 2012
                  • 45
                  Thank you for all your support. After some researching andd read a lot thee service manual i finally found something. There are a diode burn on the backside board i ateached a picture. The diode is bad. I dessolder it and test with bad result. Now i.m trying to find one for replace. It says 2bc 26c i think. It is in bad condition but it is what i read. Can someone tell me what diode can i use here for replace?
                  thank you so mutch.
                  • teckat
                    • 16092
                    thank you so mutch.
                    what pcb is that/ Transfer driver PCB
                    post a better pic
                    • carlosramosdrum
                      • Sep 2012
                      • 45
                      • teckat
                        • 16092
                        looks like the transformer T303
                        is burned out/ caused issue ?????/
                        didu remove pcb to check back area for damage ?
                        usually when u see this issue> the entire pcb is not repairable
                        R330 =FH6-3341-000 = RESISTOR, 10MOHM, 0.1W
                        R342 =FH4-9180-000 = RESISTOR, 560KOHM, 1.45W
                        IC301 =FH4-6020-000 = IC, MC-8534A, HYBRID
                        T301 =FH3-0651-000 = TRANSFORMER
                        T302 =FH3-0651-000 = TRANSFORMER
                        T303 =FH3-0538-000 = TRANSFORMER
                        T304 =FH3-0903-000 = H.V. AC TRANSFORMER
                        T305 =FH3-0903-000 =H.V. AC TRANSFORMER
                        H.V. DC PCB ASSEMBLY
                        u need to find out what caused the burn out-----
                        FG6-0910-000 - H.V. DC PCB ASSEMBLY
                        EBAY has a good used part---see link below
                        CANON FG6-0910 CLC1150 HIGH VOLTAGE DC BOARD | eBay
                        USED
                        GBP 34.99Approximately AU $53.66 Buy It NowBuy It Now
                        GBP 14.99(approx. AU $22.99) - Royal Mail International
                        • carlosramosdrum
                          • Sep 2012
                          • 45
                          • teckat
                            • 16092
                            Canon does not provide diode information > D309 is just a connection point/
                            there are no wiring diagrams that show connection paths to diodes>caps>resistors>transistors etc>etc !!!!!
                            Canon uses two companies for board repair>>>
                            but u need to register on their site/
                            for overseas repair services check with a Canon Authorized dealer in your area
                            Hytec Dealer Services
                            Factory Authorized Circuit Board Repair by Hytec Dealer Services, Inc.
                            3600 Vineland Rd Suite 121
                            Orlando, FL 32811
                            Customer Service: 1-800-883-1001
                            Phone Number: 407-297-1001
                            Fax Number: 407-297-4310
                            Technical Support: 1-888-883-2001
                            Nation-Wide Repair Service
                            Circuit Board Repair, Canon, Ricoh, Savin, Lanier Gestetner, Konica, Kyocera Mita - Nation-Wide Repair Service, Inc. (NWRS)
                            16151 Foster Street
                            Overland Park, KS 66085
                            Customer Service: 1-866-655-8676
                            Fax Number: 913-631-8372
                            Technical Support: 1-800-798-1814
                            • carlosramosdrum
                              • Sep 2012
                              • 45
                              Ok. thank You.
                              I ordered the item on ebay, and will wait until it arrives.
                              then i will post news.... want this bad dream to over, and get the printer OK.
