another ask
  • alex@wocltd.com
    • 430
    another ask
    hey guys - another ask - need firmware for Canon imagePASS-A v1.0 EFIGS , I have the firmware but will not be able to get to office tonight - and the client is 200+ mile roundtrip and with going to office that is in the wrong direction! - also what is it with sims? it has ALL the patches but not the firmware?
    Im going to load patch 1-1C7XH6 to cure E677-0010 but need to the load the firmware first to correct the error......FML
    anyone know of a place I can download it from?
    thanks in advance......
  • teckat
    • 16083
    Re: another ask
    if you have A1 Firmware/ why do u need Firmware
    never seen that patch for a imagePass A1 ??? E677-0010
    E677-0010 is usually because the IMG-CONT setting on the imageRUNNER ADVANCE must be set to 3 first and the printer re-started to confirm the setting is still set to 3 before the imagePASS is attached. If the imagePASS is attached with the IMG-CONT set to 0, there may be issues and you may need to re-install system software.
    or>>>>>>>>>>>>>Failure in Print Server. Failure was detected in operation of the CPU fan on the print server.
    If you re-install the same version of system software, be sure to re-install all software patches that were previously installed on the imagePASS.
    For a list of previously installed
    patches, refer to the Configuration pages you printed earlier.
    ??? If you installed an upgraded version of system software (for example, version 1.0 to version 1.5), contact your authorized service/support center for a list of valid software patches. Some or all of the patches listed on the Configuration pages that you printed earlier may no longer be valid. Before installing a patch, be sure to verify with your authorized service/ support center that it is valid for your system version. Installing an invalid patch may corrupt your system and may require a re-installation of system software.
