iR 5000 SSt version
  • bojans
    • 1313
    iR 5000 SSt version
    Hi folks,
    I have one iR5000 with bad HDD.
    I have tried to connect with SST versions 4.52, 4.11, 3.35, 3.21 but seems that none work. Can't format HDD with BiCentro nor network. (getting errors 105 and 107).
    My question is what is right SST version for iR 5000?
    Also what is machine default IP address?
    Thank you
  • livancicm
    • Sep 2008
    • 103
    Re: iR 5000 SSt version
    3.35 works fine. check ecp is enabled in bios of computer.
    • charm5496
      • 2387
      The 5000 doesn't support communication with the SST through the network cable. Depending on your error your the SN of the HDD might not be listed in the .ift which is in the hdformat folder. Without that you will never get it to regardless of your SST version you are running
      • bojans
        • 1313
        Thank you guys.
        Forget to mention, I have changed .ift file. ECP is enabled.
        • teckat
          • 16092
          Originally posted by bojans
          Thank you guys.
          u must have only one ver of SST registered on Laptop
          iR5000
          HDWN 'FUJITSU MPC3032AT
          HDWN 'FUJITSU MPD3043AT
          HDWN 'FUJITSU MPE3064AT
          HDWN 'FUJITSU MPF3102AT
          HDWN 'FUJITSU MHK2060AT
          HDWN 'FUJITSU MPG3102AT E
          HDWN 'FUJITSU MHN2300AT
          HDWN 'FUJITSU MHT2020AT MF
          HDWN 'FUJITSU MHV2040AH
          HDWN 'QUANTUM FIREBALL CX6.4A
          HDWN 'QUANTUM FIREBALLlct10 05
          HDWN 'QUANTUM FIREBALLlct08 04
          HDWN 'QUANTUM FIREBALLlct15 07
          HDWN 'QUANTUM FIREBALLlct20 10
          HDWN 'TOSHIBA MK6014MAP
          HDWN 'TOSHIBA MK6015MAP
          HDWN 'TOSHIBA MK1016GAP
          HDWN 'TOSHIBA MK6017MAP
          HDWN 'TOSHIBA MK2023GAS
          HDWN 'TOSHIBA MK4032GAX
          HDWN 'IBM-DJSA-205
          HDWN 'IBM-DARA-206000
          HDWN 'IBM-DJSA-210
          HDWN 'ST34311A
          HDWN 'ST34313A
          HDWN 'ST310211A
          HDWN 'ST340015A
          HDWN 'ST92011A
          HDWN 'ST340014A
          HDWN 'ST940210A
          HDWN 'IC25N006ATDA04-0
          HDWN 'IC25N010ATDA04-0
          HDWN 'IC35L040AVER07-0
          HDWN 'IC35L020AVER07-0
          HDWN 'IC25N010ATCS04-0
          HDWN 'IC25N020ATMR04-0
          HDWN 'Maxtor 2B020H1
          HDWN 'MAXTOR 4K020H1
          HDWN 'Maxtor 2F030J0
          HDWN 'Maxtor 2F040L0
          HDWN 'WDC WD400BB-22HEA0
          HDWN 'WDC WD400BB-22JHC0
          HDWN 'WDC WD300AB-00BVA0
          HDWN 'WDC WD800BB-22JHC0
          HDWN 'HDS722540VLAT20
          HDWN 'HDS728040PLAT20
          HDWN 'SAMSUNG SV2001H
          HDWN 'SAMSUNG SV0211H
          HDWN 'SAMSUNG SV0221N
          HDWN 'SAMSUNG SV0411N
          HDWN 'SAMSUNG SP0411N
          HDWN 'ExcelStor Technology J120
          HDWN 'ExcelStor Technology J64
          HDWN 'Hitachi HTS541640J9AT00
          • bojans
            • 1313
            Thank you teckat.
            Just found one of these hdd's.
            Now i need firmware version for ir5000d. I could get it in two days, but if anyone have it uploaded, please share.
            Thank you
            • bojans
              • 1313
              Got it. Thanks
