Black Mark on Bottom of the paper in ir3045
  • bineshpaul
    • Jul 2010
    • 43
    Dear,..
    I am facing a problem with Canon IR3045. When i am printing or copying the output comes with Black Mark and Solid line in the bottom of the A4 paper.
    Copy is attached herewith. pls help me,
    Thanks in advance
    Binesh
  • doktor
    • 214
    Re: Black Mark on Bottom of the paper in ir3045
    Check developing unit.
    • Herrmann
      • Jan 2006
      • 792
      check drum unit also, especially the primary roller, seems like contact is bad
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • bineshpaul
        • Jul 2010
        • 43
        I have changed the Drum unit and Developing unit but the same problem existing
        • pan
          • Dec 2010
          • 8
          hmmm , check electric contacts and the high voltage .. check fixing unit too .it seems something periodic
          • Herrmann
            • Jan 2006
            • 792
            ok, you changed drum and developing unit, so we can assume, that they are ok. On your picture one can see clearly, that the marks are in equal distance, so it must be something rotating. I would go for the transfer roller and its contacs as next step. even if it seems unlogical that a transfer roller can cause such an image.
