sound of ir4570
  • akm
    • Sep 2012
    • 155
    [Misc] sound of ir4570
    Dear CopyTechTeam,
    Please i want your help to know the source of the sound during make copy or print like ' whistle' in ir 4570 i think the sound come from the registration area what gives whistle
    Akm
  • teckat
    • 16083
    Re: sound of ir4570
    Originally posted by akm
    Dear CopyTechTeam,
    Akm
    Noise is hard to isolate/
    sounds like ? WHEWWW, or, PHEWWWWWW.
    check your clutches
    Toner can migrate into the area between the drum pin and the drum and cause the squeaking noise. To resolve this remove the drum pin and clean the surface of the pin and hole in drum were the pin enters the drum side. After cleaning reinstall the pin into the drum assembly and reinstall the drum unit into the machine.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      Re: sound of ir4570
        Re: sound of ir4570
        The registration clutch can cause this.
        Remove the main drive assembly, 4 screws, do not touch the round head screws or the drive assembly could fall apart.
        • mjarbar
          Re: sound of ir4570
          It could also be the drum is due for a change, the machine is out of toner (some give no warning I have found!), the main drive motor etc...
          As everything is centralised on these machines, any noise from the process area is hard to pin down. It also depends on the type of noise - continuious or intervals, what sort of intervals?
          Before settling on what it could be, I think a little more info may help!!!
          • teckat
            • 16083
            Re: sound of ir4570
            Whew- a whistling sound or a sound like a half-formed whistle uttered as an exclamation
            -used interjection-ally, chiefly to express amazement, discomfort, or relief
            Phew- used to express relief or fatigue
            So u see, Whew! can be a Phew! but Phew! cannot be a Whew!.
            as in
            Whew! I am amazed at my findings,
            Phew! I am glad this post is over.
            • mjarbar
              Re: sound of ir4570
              as in
              As opposed to a Peep, Wheep or a phoot!!!
              • Rachid.Akli
                • Oct 2011
                • 595
                Re: sound of ir4570
                Hi to all,
                I send you the timing chart. It may help to determine the origine of the sound. You can also, open the rear of the machine and try to detect what element is starting to turn when you hrear the sound. You can also, try with testing the motors in Function mode > PART-CHK.
                Rachid.
                Timing charts.pdf
                "Find a job you love and you’ll never have to work a day in your life." Nagy's father
                • akm
                  • Sep 2012
                  • 155
                  Re: sound of ir4570
                  [ATTACH=CONFIG]18103[/ATTACH]
                  hi skynet many thanks for your support i clean the registration clutch , the axe and the sound disappear
                  akm
