Configure IP ImagePressC1
  • floydtheduck
    • Aug 2025
    I'm a SysAdmin that recently replaced someone that left the company. We have an ImagePressC1 that has an IP already set which I would like to change (moving to a different VLAN/Subnet). I don't have a ton of experience with Canon copiers, but I've used a Fiery before and in my past experience this would be done by:
    Go to http://IP-Address
    Go to Configuration (tab)
    Click 'Launch Configure'
    A Java applet would launch and you would configure it there after putting in the credentials.
    My problem is... I can't get to the Java applet. I see the Java symbol load/spin, then it prompts me for credentials. I put in the default F.....1 password (I've read it's taboo to post this publicly), and the background just turns grey. At first one would think that this means I have the wrong password. I was able to confirm with the person who was here previously that he left it as the default. However, I've also had issues with the Java applet in the past with other Fiery machines.
    So my questions are:
    1. Am I going about changing the IP correctly?
    2. Is there a trick for getting the Java applet to load?
    3. If I am doing the above correctly, perhaps I have the wrong password. Is there a way to reset it? (note: currently no one uses the copier for anything other than... copying. No one prints or scans to/from it)
    Thanks, in advance, for your help.
    Ben
  • teckat
    • 16083
    Re: Configure IP ImagePressC1
    Ben
    never believe they left it as a defaultdo u have a Q1/Q2 imagePress server attached to printer
    u see a Printer Tab on imagePress control panel ?
    open it to log on = Fiery.1
    change settings
    if u can't log in there is a Fiery Password Tool that will show the Password loaded-Print the *.ps file, and then a Page comes up with the password...
    password(1).zip
    or look for it here---with full instructions
    http://www.copytechnet.com/forums/co...eval-tool.html
    • floydtheduck
      Yes, I have an ImagePress Q1. I meant to say that in the OP but I forgot
      I'll try your instructions and post back.
      Thanks!
      • floydtheduck
        I'm downloading the file now, it's pretty large and will take 3 hours to download.
        In the meantime... I looked for a 'printer' tab as mentioned above, but could not find one. I only have the 'Launch Configure'... anything else under Configure only displays current settings, it doesn't allow me to modify.
        I tried intentionally entering an incorrect password and it gave me an error saying it was incorrect. Since I don't get this error when using Fiery.1 then I assume this is correct and that I have a Java issue.
        Can anyone advise in regards to the Java issue? I've tried modifying settings, using XP and 7, using IE6, IE8, IE9, Chrome, and FF to no avail.
        Thanks!
        • teckat
          • 16083
          Thanks!
          where are u entering Fiery.1 ????
          what is taking 3hrs ?
          zip file opens in 10sec.
          On the Control Panel --
          1) Press (=>) displayed at upper right on the LCD .
          2) At the Control Panel, press [Printer].
          3) Press [Printer Status/Settings].
          if u don't see it >u need to go in printer service mode
          COPIER>OPTION>INTFACE>IMG-CONT
          and set it to '3'/power off/on printer
          SERVICE MODE
          press Additional Functions Key (once)
          press #2 & #8 key at the same time (release both)
          then press Additional Functions Key again (release it)
          • floydtheduck
            The Command Worksation utility that is used with the zip file.
            • teckat
              • 16083
              [ATTACH=CONFIG]18108[/ATTACH]
              OK !/ RUI i see--
              here is the Q1 MANUAL to better explain---
              try and do it from my post above>using printer control panel
              it will bring up following menus>>>
              • teckat
                • 16083
                U usually don't use Fiery.1 in RUI as a log in/under Admin ??
                In service mode go to SERVICE MODE>CLEAR>PWD CLEAR and hit ok. This will remove the admin passwords for the machine. Log into RUI. Once RUI is accessed, the RUI Administrator password can be left blank or set up in Device Manager > Information >RUI Administrator password.
                • floydtheduck
                  U usually don't use Fiery.1 in RUI as a log in/under Admin ??In service mode go to SERVICE MODE>CLEAR>PWD CLEAR and hit ok. This will remove the admin passwords for the machine. Log into RUI. Once RUI is accessed, the RUI Administrator password can be left blank or set up in Device Manager > Information >RUI Administrator password.
                  This isn't the RUI (assuming you're referring to what's on the first tab, which is Launch Remote UI, which has a similar interface as is on the control panel on the actual printer)... it's the configuration app. Please refer to my previously attached image. I'm pretty certain it's an issue with Java loading.Thanks for the help.
                  • teckat
                    • 16083
                    simple fix is to go the imagePressC1 control panel way>
                    get over to run setup & put in your new IP Address/
                    have done it hundreds of times on moved/location Canon Printers with a Fiery connected
                    • floydtheduck
                      simple fix is to go the imagePressC1 control panel way> get over to run setup & put in your new IP Address/have done it hundreds of times on moved/location Canon Printers with a Fiery connected
                      Thank you, that did the trick.I'm still a bit curious about the Java issue, though. But I suppose it doesn't matter now.Thanks for your help.
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        Fieries can be quite persnickety when it comes to Java.
                        It's also possible that there is an issue with the system software on the Fiery, but as long as you can get it to print and work OK, no point in going down that road, as it would take a qualified Canon tech to install. (Plus there is no place you can download it from.)
                        Command Workstation is a great tool for managing your Fiery and the print jobs; I'm sure you'll like it.
                        Funny, the current PC version is something like a 1.2GB download. The original version (circa 1997) was contained on 3 floppies!
                        • teckat
                          • 16083
                          COLOR HAND.jpgwelcome~~~~~~~~~~:
                          remember>>>> JAVA + CANON = Aggravation
                          • bassam
                            • Apr 2013
                            • 7
                            ImagePressC1
                            hello all ,i lose cds driver imagepress server q2 how can find it and can back the files fiery to can work again with cannon c1? thanks to anybody help me.
                            • teckat
                              • 16083
                              Re: ImagePressC1
                              u mean u lost the Q2 Firmware CD's or the Driver CD's
