Canon IR4570
  • crazysick
    • Aug 2025
    [Jamming] Canon IR4570
    Hi,
    I have Canon IR 4570 copier. I have changed the fuser fixing film last week. Right now, i m facing paper jams problem after changing the film. Can anyone suggest me what to do. Thanks
  • dickiebob
    • Sep 2011
    • 66
    Re: Canon IR4570
    Originally posted by crazysick
    Hi,
    Why did you need to change the fixing film?
    What jam codes are there?
    • crazysick
      Re: Canon IR4570
      Originally posted by dickiebob
      Why did you need to change the fixing film?What jam codes are there?
      Hi there, There is no error code at all. I did change the film as it didn't fuse properly (easily can wipe out the toner with hand). No error code was showing on the panel. After chaning, Copy 1 or 2 pages is ok. But paper jam occured when continuous copying. I think that my way of doing was wrong. Tuanks for help.
      • Brian8506
        • 1665
        Re: Canon IR4570
        Jams are in service mode. Did you clean off the old grease and apply new grease? Is the fuser pressure on?
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Re: Canon IR4570
          Hi,
          My advice
          Follow PDF procedure..........procedure.pdf
          • crazysick
            Re: Canon IR4570
            Originally posted by zoraldinho
            My advice
            Follow PDF procedure..........[ATTACH]18157[/ATTACH]
            Thank you so much indeed. I will try by following this procedure tmr. Once again, thanks deeply. cheers
            • crazysick
              Re: Canon IR4570
              Hi,
              I cleaned off the old grease and applied the new one. the problem is happened on continuous coping or printing. First , second page is ok. Fusing well. No jams. Thanks for the advice Brian.
              • Rachid.Akli
                • Oct 2011
                • 595
                Re: Canon IR4570
                Hi,
                Use canon genuine parts and you will get rid of your troubles.
                Rachid.
                "Find a job you love and you’ll never have to work a day in your life." Nagy's father
                • spectraindo
                  • May 2008
                  • 313
                  Re: Canon IR4570
                  If you have replace the fixing film only, put 10 drops of fuser oil/silicon oil on the fixing heater element so it will lubricate the new film and causing it to turn smoothly.
                  Jamming is caused mostly because the film does not turn.
                  • Canon.Tech
                    • Mar 2009
                    • 335
                    Re: Canon IR4570
                    As Rachid.Akli says if you use Genuine Canon fixing film unit you won't have any jamming poor fixing issues, the non OEM films are just not worth using on this model especially as the genuine Canon ones last over 250k I have many that do 500k!
