Canon CLC 1150 touch screen display panel disaligned
  • elpenot
    • Nov 2011
    • 11
    Hi guys,
    Is anyone knows how to correct the touch screen display of Canon CLC1150? Pressing directly in one of the buttons on the touch screen display panel it will not work, what I did... I press a little bit below the buttons and it works. It seems like there is a part of the touch screen display panel shifted down a little bit. I need your help guys. Thank you in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon CLC 1150 touch screen display panel disaligned
    1) Press the asterisk keyadd func.jpg on the control panel.
    2) Press '2' and '8' on the keypad at the same time.
    3) Press the asterisk key on the control key.
    COPIER>FUNCTION>PANEL
    LCD-CHK=checks the LCD for missing dots (OK key to start; all
    dots turned on, and changed to blue; Stop key to stop)
    LED-CHK=starts a check on the LEDs on the control panel (OK
    key to start; LEDs turned on in sequence)
    KEY-CHK=starts a check on key inputs from the control panel
    TOUCHCHK=checks the touch panel of the control panel (+
    indicated on LCD pressed repeatedly to move
    through highlighted items)
