error codes after replacing drums on Adv 2020L / 2030
  • pan
    • Dec 2010
    • 8
    Hi all,
    if the drum life of drums is above 170 % and highereverytime i go to replace the drums with new a have problems with error codes for each new drum.
    i haven't find the solution yet.
    help !
    thank you
  • Joseph2011
    • Aug 2011
    • 88
    Re: error codes after replacing drums on Adv 2020L / 2030
    Originally posted by pan
    Hi all,
    help !
    thank you
    good evening:
    same thing happened I put drum's C / M / Y / K goes new error code that says not recognize the drum's, what I've done is put the drum contacts the old to the new and the problem was
    Another alternative is that when you change the drum's non-performing steps of the service manual (which says off the band and drum) Carefully place and problem solved
    I leave two alternatives that have worked for me
    regards
    • teckat
      • 16083
      Hi all,
      help !
      thank you
      what error codes ???
      who is replacing the Drums ? a USER/Customer or a Tech ???
      • canonbundy
        • Jun 2012
        • 607
        Stick with OEMs and save yourself a lot of time & money.
        • pan
          • Dec 2010
          • 8
          Originally posted by Joseph2011
          good evening:
          regards
          thank you , i'll try it
          • Rachid.Akli
            • Oct 2011
            • 595
            Hi to all,
            Letting the drums work above 100% leads to a loss of toner and developer that will fall on the laser. When replacing new drums, the patch density will be light. E020 error code is displayed.
            In your case, clean the laser and try to replace your drums arround 120%.
            Rachid.
            "Find a job you love and you’ll never have to work a day in your life." Nagy's father
