Canon C3220 printing issues
  • kuby
    • Oct 2007
    • 1374
    Have never seen this before. Customer tries to print and the Copier shows a message "Suspeded" and when you go to details is shows "PDL Data transfer error". Looked at the copier everything seems to be OK. Nothing changed on copier. Cancell the print job and samething. After about 5 times of turning it Off/On it will finally allow them to print. The computer is not turned off at night, when they come back in in the morning, same issue. Going to hook up my laptop direct to copier to try and eliminate network or other computer problems.
    Anyone every run into this???
    Have installed new driver and same issue
  • vbei
    Re: Canon C3220 printing issues
    Have you or the customer tried re-installing the driver?
    • kuby
      • Oct 2007
      • 1374
      Thanks did that already
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5000
        Do you have the same issues with copying?
        What accessories are installed?
        Check acc. connections.
        Try printing without acc.
        Always re-seat and clean memory!
        New firmware.
        • kuby
          • Oct 2007
          • 1374
          No problem copying. Removed finisher, same problem when printing.
          • teckat
            • 16083
            If u have a Multi PDL Kit installed instead of a Fiery>
            remove board>clean and re-seat it
            when connected to a imagePass >have once seen a bad interface cable cause that message
            • kuby
              • Oct 2007
              • 1374
              Yea thought of that too, no Imagepass on machine.
              • teckat
                • 16083
                Is this the kit that has a dongle that need to be registered /and can't be transferred
                • kuby
                  • Oct 2007
                  • 1374
                  No dongle
                  • teckat
                    • 16083
                    No dongle
                    sorry, thinking of the Universal Send Kit dongle used on some models
