paper jams on the IR 3035
  • Reeves
    • Apr 2012
    • 294
    [Jamming] paper jams on the IR 3035
    i have a canon ir 3035 copier with continue paper jams just after the paper is about to come out of the fuser unit.i have replaced the all fuser but the problem is still there the error code is 0108 please advice
  • vbei
    Re: paper jams on the IR 3035
    Check your flapper on the door, might be broken or the sponges could compressed (worn).
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 4999
      Jam probably have nothing to do with fuser.Check delivery sensor.(PS14)
      • canonbundy
        • Jun 2012
        • 607
        Does the paper want to follow the Hot Roller around? If so, is the machine in a very high Humidity area? If so, the paper will be damp and you will probably require a Cassette Heater & PCB.
        • Reeves
          • Apr 2012
          • 294
          No the paper is just jamming just after it comes out of the fuser unit that is in A4 but A4R is working okey
          • canonbundy
            • Jun 2012
            • 607
            This is probably a dumb question, but is the offending tray dial set to the correct orientation?
            • Brian8506
              • 1658
              The first thing I look at for 0108 jams are the black damper pads on the gate on the door. They get soft and compressed and the gate sticks to them. This is what vbei is referring to.
              • canonbundy
                • Jun 2012
                • 607
                I'm thinking you may have a busted tray & the paper is feeding outside of the machine guides, especially if the A4R tray is ok.
                As you say the A4 tray (assuming tray 1) is causing the jams - check if the rear paper guide inside the cassette moves independantly of the front adjusting guide, if so 1 or both of the gear shafts will be broken and when the cassette is shut into the machine the weight of the paper pushes the guide to the rear therefore the paper is fed up to 5mm outside the inlet guide of the fuser.
                • Reeves
                  • Apr 2012
                  • 294
                  Thanks for your reply it worked
                  • Reeves
                    • Apr 2012
                    • 294
                    Thanks for the information it worked
                    • mpmamaril
                      go to system mode clear all errors there and try it.... and also check all paper sensor.. just clean it
                      • Brian8506
                        • 1658
                        Good job. Thanks for posting back.
