IR5570 Print, copy, black copy zebra pattern
  • zibros
    • Sep 2012
    • 31
    [Misc] IR5570 Print, copy, black copy zebra pattern
    Please help me (refer to attachment files). my canon ir5570 produces a zebra pattern in every print, copy and also black copy
    The action I did:
    1. I replaced the primary, separation,
    transfer charging wire and pre-transfer charging wires -------.> no result
    2. I assumed the problem may be on the spacer roller in developing, so I changed the developing assembly with the other mechine Ir 5570 (which it is normal condition) ---------> also no result
    3. I did FUNCTION > CLEAR > ERR to MN-CON ---------> no result
    Note: the counter 1,568,675
    Any suggestion? for this problem
    Zibros
  • Alex ahir
    • May 2012
    • 125
    Re: IR5570 Print, copy, black copy zebra pattern
    Try clear DC,
    or try change high voltage board
    • Rachid.Akli
      • Oct 2011
      • 595
      The action I did:
      [ATTACH=CONFIG]18268[/ATTACH] [ATTACH=CONFIG]18269[/ATTACH]
      Zibros
      I assume that your first attachment is supposed to be black. This may be a consequence of the dev assembly which is not turning continously. Have a look on it and also, try to clean or replace the dev clutch.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • Simons
        • Jun 2008
        • 492
        Also check gears and smooth turning on the dev unit.
        • zibros
          • Sep 2012
          • 31
          Rachid.
          Thanks for your comment
          where is it that you mean dev clutch in developing assembly?. I am not replaced yet but I use other developing from other machine same type, but the result is same
          • songela
            • Mar 2008
            • 216
            The action I did:
            Zibros
            It is very likely this comes from the T/S Unit. Under isolated cases, even the new ones have been found to leak the high voltage.
            Secondly, check what kind of toner is used, substandard (compartible) toners can exerggerate the problem where the T/S unit is weak.
            Also, the pre-transfer corona can improve matters, check if it is in place.
            • zibros
              • Sep 2012
              • 31
              Originally posted by Alex ahir
              Try clear DC,
              you mean clear dc is FUNCTION > CLEAR > DC-CON ?, I did that, no success
              could you explain the step how to change high voltage board?
              • zibros
                • Sep 2012
                • 31
                Sorry I don't understand the unit T/S?, could you recommend me the step what I should to do related your comment?
                • songela
                  • Mar 2008
                  • 216
                  Transfer/Separation Unit OR simply the Transfer corona assembly.
                  Make sure there is no leakage on it, no matter it is new or old; you fit the same to a different machine and judge it by copy quality comparison.
                  • zibros
                    • Sep 2012
                    • 31
                    Transfer/Separation Unit OR simply the Transfer corona assembly. Make sure there is no leakage on it, no matter it is new or old; you fit the same to a different machine and judge it by copy quality comparison.
                    Thanks Songela I think you are right, I try to use the transfer/separation corona assembly from other ir5570, the result back to normal, but only for some pages and back again to the problem. I try to ADJUST > HV-TR > D-PRE-TR from -2 to 0, D-HV-TR -2 to 0 and ADJUST> HV-SP > D-HV-SP from -2 to 0 the result normal again for some pages and back again to the problem.
                    What's happening, Songela please your advise again Regards Zibros
                    • Rachid.Akli
                      • Oct 2011
                      • 595
                      Clutch part number is: FK2-0209-000000 CLUTCH, ELECTROMAGNETIC CL1 J1001
                      Rachid.
                      Dev clutch.pdf
