Unclear Image
  • Engels
    • Aug 2012
    • 10
    Unclear Image
    Good Day! Greetings from this end! Please, I am having this unclear image (blur) with my canon IR1133 after photocopy. I discover that the right end from top to bottom is blur. I need help, please! Thanks so much.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Unclear Image
    Do you have unclear image from glass and ADF?? What about print?
    • Mikey
      • Sep 2009
      • 54
      Re: Unclear Image
      The information you presented is incomplete. Make sure that the original is laid flat on the platen glass. Make internal test print and compare with copy print. If the same problem occur on both then replace the toner cartridge. I hope this helps.
