UST= User Support Tool Information
  • teckat
    • 16083
    [Misc] UST= User Support Tool Information
    UST= USER SUPPORT TOOL INFORMATION
    imageRUNNER 2525 / 2530 / 2535 / 2535i / 2545 / 2545i
    How to start the UST to load System Software-
    When reaching the point where the download instructions state to "Start up the UST", you must go to the sub-directory where the SSW is stored and choose the EXE file. When you double click on the EXE file the UST will open.
    Upgrading Copier SSW on the iR2545 device--
    see pdf----------------------Upgrading Copier SSW on the iR2545 device.pdf
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: UST= User Support Tool Information
    For everyone who have trouble upgrading this model with SSt.
    • teckat
      • 16083
      • DAG COPIERS & COMPUTERS
        • Oct 2010
        • 860
        Originally posted by teckat
        [ATTACH=CONFIG]18299[/ATTACH]
        Thank you very very much teckat for that valuable information about the UST, and also for this QUOTE of wisdom from Mahatma Gandhi.
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          Hello it is best information to knowing all technology ..so l know the sst is free ...l it have any possibility to have it this ust ?
          BEST TECHNICIAN . NICE PEOPLE .
          • teckat
            • 16083
            UST Firmware is in the Models UST Firmware Folder location--
            in an EXAMPLE as shown below
            C:\Canon File Folder\SST System Software Folder\UST Files\CiRC1022_v61.01.01
            UST Firmware Models/ & also used in their compatible Euro models
            CiR LBP5280
            CiR LBP5460
            CiR LBP5480
            iR LBP3460
            iR LBP3470
            iR LBP3480
            iR LBP3560
            iR LBP3580
            CiR C1022/C1022i
            CiR C1030/C1030iF
            iR 1730/1740/1750
            iR 2545/2535/2530/2525
            LC 810/830i
            • zaza
              MECANOGRAPHE
              • Mar 2008
              • 1095
              so what's up about the ir2318 ..1018....model ...he function as ust ?
              • teckat
                • 16083
                When updating the firmware, start the User Support Tool first and then select the machine to update.
                iR2318-iR2420/2320/2422
                use UST firmware
                but for their Finisher U2 u need SST+Downloader PCB-
                These machines can be upgraded by downloading system software programs from the personal computer (hereafter called as the PC) in which a user support tool (hereafter called UST) has been loaded.
                The Finisher option can be upgraded by downloading system software programs from the personal computer (hereafter called as the PC) in which a service support tool (hereafter called SST) has been loaded.
                iR1018 / iR1018J / / iR1022A / iR1022F / iR1022i / iR1022iF /
                use SST Firmware=
                - Main controller: System
                - Boot program: Boot
                - PCL board: PCL
                • Rachid.Akli
                  • Oct 2011
                  • 595
                  Hello everyone,
                  I have an IR2420 displaying something related to a "BIOS" (sorry, i don't remember the exact message) . I tried to download system using the UST and an USB connexion as the machine doesn't have a network connexion by default. I got the a message requiring an IP address input. I supposed that the image processing PCB is faulty and doesn't allow data transfer. I solved the issue by replacing the main controller.
                  Is there any other experience about this ?
                  Rachid.
                  "Find a job you love and you’ll never have to work a day in your life." Nagy's father
                  • zaza
                    MECANOGRAPHE
                    • Mar 2008
                    • 1095
                    trying connecting your pc directly by the HDD of this machine surly if you have error code message consisted this parts of machine .
                    • Rachid.Akli
                      • Oct 2011
                      • 595
                      Hello,
                      There is no HDD.
                      Rachid.
                      • teckat
                        • 16083
                        Originally posted by Rachid.Akli
                        Hello everyone,
                        Rachid.
                        u should not be receiving message about IP address
                        -u must have printer off
                        connect laptop to printer>then open/start up UST
                        -now power up printer
                        if a found new hardware pops up >select cancel
                        Press the Additional Functions key on the control panel of this machine to enter into the user mode.
                        -Press the down-arrow key to select "System Settings", and then press the OK key.
                        -Press the down-arrow key to select "Update Firmware", and then press the OK key.
                        -When "OK to update" appears, select “Yes” and then press the OK key.
                        -When "PLEASE WAIT WAITING" appears, start the UST.
                        • ziribe
                          i have message *mode bios " ir2422 please help me
                          • Winston
                            I have a problem with the printer Canon IR2318. Please tell me where to get UST?
                            • Winston
                              I have a problem with the printer Canon IR 2318. Please tell me where to get UST application?
