IR7095 IP setting
  • msmy
    • May 2010
    • 123
    IR7095 IP setting
    I bought 2 used IR7095 machine. One of the machine I can set the IP successfully. However, the another one, I can't set the IP address. I can't find the button for IP setting. When I go to network setting, there are only 2 option (Change setting... and TCP/IP setting there are no other option, such as netware, Alpletalk etc). when I touch the TCP/IP setting, there are only show proxy setting...)
    Help please...
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: IR7095 IP setting
    Probably is RIP installed. Go to printer settings.
    • msmy
      • May 2010
      • 123
      How to solve this issue?
      • spectraindo
        • May 2008
        • 313
        Go to Service Mode :
        COPIER > OPTION > INT-FACE : IMG-CONT = 0 .
        • msmy
          • May 2010
          • 123
          Problem solved. Tqvm.
          • msmy
            • May 2010
            • 123
            Hi,I can set IP for this machine. I successfully install the printer driver (PCL 5). Computer can detect the printer, however I cannot print. Any other setting to handle? When I want to print the report setting, there are only network button is appeared.
            Not like another machine I have, which is two button (network, printer) appeared.
            please help.
              • 16083
              [ATTACH=CONFIG]18543[/ATTACH]
              [ATTACH=CONFIG]18544[/ATTACH]
              please help.
              1. Shut down the copier. Power off the finisher. Re-seat all of the connectors between the finisher and the copier. Power on the finisher. Wait 3 seconds. Power on the copier.
              2. Try clearing MMI on the copier. Reboot the copier.
              * IMPORTANT - Be sure to back up all settings and data before clearing MMI.
              • spectraindo
                • May 2008
                • 313
                Check your BOOTROM TYPE , maybe it is a C type. C type cannot print.
                The N type BOOTROM can print.
                • msmy
                  • May 2010
                  • 123
                  Both of the machine use type A.
                  • spectraindo
                    • May 2008
                    • 313
                    There is no BOOTROM type A.
                    Look at : SERVICE MODE > COPIER > DISPLAY > VERSION > BOOTROM
                    It should look like this : --.-- C or --.-- N
                    If it is the C type you must have Multi PDL Printer Kit H1, the BOOTROM comes with the Printer Kit.
                    • msmy
                      • May 2010
                      • 123
                      Yes. you right. I checked today and its show type 50.47_C. So, what can I do so that I can use this machine as printer?
                      thanks
                        • 16083
                        thanks
                        I thought u were a tech
                        U need to research you acquired products
                        October 2007
                        for use with "C" Boot Rom ( Boot Rom comes standard in printer)
                        The Multi-PDL Printer Kit-H2 provides printing functionality to the general office user when the vast majority of output is text-intensive.
                        When the imageRUNNER 7105/7095/7095 Printer/7086 devices are configured with the optional Multi-PDL Printer Kit-H2, connected users can access virtually every document/image manipulation feature, paper source and finishing mode available to walk-up copier users right from their desktop. Plus, it offers a host of other capabilities that are only available for print jobs, like Secure Print, Print to Mail Box, and Edit and Preview.
                        The Multi-PDL Printer Kit-H2imagePASS-S2 (which includes the "N" Boot Rom)
                        The imagePASS-S2 is an external print controller that supports true Adobe PostScript 3 printing and MEAP functionality.
                        This controller features an Intel Celeron D 2.8 GHz processor, an 80 GB Hard Disk Drive, and 256MB DIMM memory.The Command Workstation management tool is available for Job Management, Archiving, Variable Data, Job Logs, Font Downloading, and Document Building.
                        The optional features can be added when the device is configured with the imagePASS-S2, including Hot Folder support and EFI Impose.
                        • msmy
                          • May 2010
                          • 123
                          October 2007
                          What should I do to make this machine able to print?
                            • 16083
                            Can't spell it out any easier
                            The following optional equipment is required for printing from a computer:
                            Printing
                            If you want to use the UFR II/PCL printer driver
                            - Multi-PDL Printer Kit
                            If you want to use the PS printer driver (either of the following)
                            - imagePASS
                            The optional Multi-PDL Printer Kit cannot be used if the optional imagePASS is installed.
                            Multi-PDL Printer Kit-H2 (0527B003BA) is now available for the imageRUNNER 7105 v2 / 7095 v2 / 7086 v2 Series(0512B032AA).
                            The Multi-PDL Printer Kit-H1 (0527B001BB) will still be available for the imageRUNNER 7105 / 7095 / 7086 devices. When the Multi-PDL Printer Kit-H1 is no longer available, the
                            Multi-PDL Printer Kit-H2 can be installed with the imageRUNNER 7105 / 7095 / 7086 devices with a system software upgrade. The main unit system software must be V.50.xx or higher. When installed with the Perfect Binder-A1, the Perfect Binder-A1 system software must be V.20.xx or higher.
