Canon PC475
  • mecanic
    [Misc] Canon PC475
    Have a Canon PC475 that only copies a 1/4 of the image.
    Have hand fed and held the paper back - this gives full image
    so there is a travel or timing issue - any suggestions?
  • Canon.Tech
    • Mar 2009
    • 335
    Re: Canon PC475
    Sounds like the registration clutch is either sticking on or slipping.
    Open up the machine, just under the cartridge you will see the registration roller, & the end of that is a clutch.
    Try a few drops of oil or spay some WD40 on it that usually gets it going again.
    If not you will need to remove that unit, this allows you to remove & clean the clutch.
