Hi all,
I had a problem where a machine would jam in the initial feed assy on the right hand side when feeding from tray 2. Tray 1 was fine and i didn't try the bottom two cassettes at this point.
I had a spare pickup assy in my car but before swapping it for a new one i just swapped the pickup assy's of 1 and 2 around (to try and narrow down whether the problem was with the pickup assy or something else)
The machine worked on both trays, so i performed the usual checks to make sure the machine works fine without any jamming from the top trays for a lot of copies.
As soon as i tried the 3rd tray it would jam, but this where it gets weird - it will feed one piece of paper fine, i can do as many single sheets as i want, the second i try to do one or more sheets the machine jams...in the fuser!
Tray 1 works fine, tray 2 works fine and tray 4 works fine, on all paper sizes.
But no matter what i do with tray 3 it still jams but way over in the fuser!?
I've swapped the pickup assy for tray 3 for a new one incase this caused a problem and it didn't change anything, i tried swapping the entire tray around too and this still didn't solve my problem.
It's a very weird fault as it's only from tray 3 but jams way over in the fuser.
Any ideas would be greatly appreciated!
Jamesu
Jamesu
