canon ir3300 paper at tray 2 not detected
  • msmy
    • May 2010
    • 123
    Hi,
    Any idea why canon IR3300 tray 2 not detect paper? When I put the paper, the tray lift the paper. However, the machine still showed there are no paper at this tray.
    help please...
  • Canon.Tech
    • Mar 2009
    • 335
    Re: canon ir3300 paper at tray 2 not detected
    The lifter cam usually breaks, also check there are no small pieces of paper trapped behind the cassette, use a torch, only needs to be a small piece to cause load paper.
    • bineeshgeorge
      • Jul 2009
      • 107
      check the battery and tracks near the battery on the dc controller pcb,, it may be damaged due to battery leakage....
      • dan7777
        • Dec 2012
        • 680
        Originally posted by msmy
        Hi,
        help please...
        There is a gear that breaks (or cracks). I was told it was really difficult to replace so work let me replace the entire feed assembly with a known good one. Usually it will detect paper if the tray is full but not when it gets lower. I don't know which gear or have a part number. The entire feed assembly is not that difficult to take out. I think it has to be out to replace the gear(s).
        • northernlife
          • Sep 2011
          • 847
          Sector gear is broken. 100% guaranteed. It's in the paper pickup assembly. I believe teckat has the instructions for how to change that one. We've got so many used 2200's that we just swap the ppu assy and chuck the old one.
            • 2621
            Replacing that gear doesn't look easy..
            • msmy
              • May 2010
              • 123
              [QUOTE=skynet;332633]Replacing that gear doesn't look easy..
              thanks guys.
              Now the problem solved.
              • northernlife
                • Sep 2011
                • 847
                One of the hardest things I've had to work on and it's not that hard. Just this gear is spring loaded against these two cams, etc... It's doable it just sucks
                • campy
                  • May 2012
                  • 315
                  The bottom one is easy, try doing the top one.
