Canon IR5000 wired jamming
  • mramlawi
    • Jul 2011
    • 838
    Dear all ,
    i have canon ir 5000 its jamdded always befor enter the rigistration some time it enter ,actually it first time i faced like this problem the jam code is 020F,some times 0207 using the first drawer and also the third one same jam ?!
    i cleaned the back Clutch of the unit 1 which located on the back of the regisrtation unit but nothing happen any ideas .
    thanks
    Distinguished road makes you jewel in rough
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Re: Canon IR5000 wired jamming
    Does the jam occur on all cassettes?If so check on the paper guide before the registration roller.
    If paper jams on particular cassettes ,check on the paper feed rollers and the separation rollers on the feeder units.
    • mramlawi
      • Jul 2011
      • 838
      hello thanks for the reply yea all the cassettes jams :S
      • Rachid.Akli
        • Oct 2011
        • 595
        Salut,
        0207 is a stationary jam at the right deck feed paper sensor (PS32) ===> replace the rollers.020F is also a stationary jam : claw jam sensor (PS4) ===> Paper doesn't leave the sensor at the required time interval.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
          • Aug 2011
          • 279
          Check on the sensor flag of the pre-registration sensor and ensure that it plays freely.
          Try to check the paper passage before the registration rollers and try to interchange the sensor to ensure its efficience .
          • mramlawi
            • Jul 2011
            • 838
            thanks for all , i solved it was the sensor for the feed unit of the 1st drawer , the sensor was stuck i wrapped the spring of it and it works
            regards ,
