Canon ir5000i scan to network folder problems
  • kuby
    • Oct 2007
    • 1414
    Have a server running Small Business Server 2003, XP and Windows 7 computers, have a Netgear Switch, Firewall turned OFF.
    When trying to scan to a network folder on a personal computer or the server it keeps telling me to "check the server, can not log in".
    Now I can see the computers and server on the screen but can not access them, I have several systems doing the same thing. Any suggestions? Thanks
  • tieuquyen
    • 33
    Re: Canon ir5000i scan to network folder problems
    Hi
    Did you used domain on your system network, if you did, the you must be registed your Canon into domain and then you can use network scan. hope this help
    • kuby
      • Oct 2007
      • 1414
      Yes it was registered, the problem was with the server not allowing the digital signature to pass. Fixed it. Thanks
      Click Administrative Tools > Domain Controller Security Policy
      Under Security Settings > Local Policies > Security Options
      Scroll down to Microsoft network server: Digitally sign communications (always) and Disable it
      This only applies to SBS 2003
      so far we found that it comes enabled on this version.
      • teckat
        • 16083
        share > what was your fix/finding ?
        • Simons
          • Jun 2008
          • 490
          Id like to know too
          • kuby
            • Oct 2007
            • 1414
            Now the fix only applies to the scan to a folder on the server, scanning to a Win 7 machine it is still unavailable. Has to be a setting in there also, just have to find it.
