problem ipf 755 canon
  • Joseph2011
    • Aug 2011
    • 88
    I have an TWO error
    03130031-2F3A AND
    03130031-2F2Aon my Canon iPF755,
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: problem ipf 755 canon
    03130031-2F3A valve open/close error
    <Cause>
    When the ink supply valve opened or closed, valve open/closed detection sensor could not detect the valve cam rotation.
    <Probable fault location>
    Valve open/closed detection sensor, valve motor, or main controller PCB
    <Countermeasure>
    1) Visual check
    Remove foreign substances from the motor, gear, and sensor of the valve open/close mechanism if any.
    2) Valve open/closed detection sensor
    Select [SERVICE MODE]>[I/O DISPLAY] to check for normal operation. If the operation is abnormal, replace the valve open/closed detection sensor.
    3) Valve motor
    Select [SERVICE MODE]>[FUNCTION]>[INK VALVE] to check for normal operation. If the operation is abnormal, replace the valve motor.
    4) Replace the main controller PCB.
