c3380i E20-23 error code
  • Geohofer
    • Jul 2025
    [Error Code] c3380i E20-23 error code
    The machine I'm working on is sending the E20-23 error code after replacing the BK drum. The machine was moved to a new location, and the drum was at 108% and a new one installed. Does anybody know how to check the ATR sensor and how to run the Patch test on the other drums in service mode. If the sensor works on the color other drums I can assume the ATR isn,t faulty and that my new drum is probably bad.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: c3380i E20-23 error code
    Black drum definitely.Clean the ATR sensor window anyway.
    • Rachid.Akli
      • Oct 2011
      • 595
      Hi to all,
      Clean the laser with the cleaning device.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • Geohofer
        Originally posted by Rachid.Akli
        Hi to all,
        Rachid.
        That did it!!!
        I got a diffrent drum cartridge before I tried the cleaning routine. I did the cleaning sometime before but I guess I wasn't thourgh enough.
        gh
