Firmware Request - C3200
  • gbestwick
    • Jun 2025
    Hello!
    I realize I'm a new member here and I'm imposing requesting this without participating so far.
    However, I'm in a real pickle right now and am in desperate need of the firmware for the C3200. I am in possession of the appropriate tools to load it, so all I will need is the firmware.
    If anyone would be so gracious to assist me I'd be tickled pink!
    You can message me here, or gbestwick@shaw.ca
    Cheers
    Gord
  • alexctx
    • Dec 2010
    • 158
    Re: Firmware Request - C3200
    which is bad?
    imagePASS c1. or. iRC3200
    • teckat
      • 16083
      Originally posted by gbestwick
      Hello!
      Cheers
      Gord
      asking>> what exactly is your problem on the 3200----
      • gbestwick
        The problem is that the hard drive is toast and the local canon shop doesn't have "any in stock", and will take an amount of time that is much longer than what we can wait.
        So, I've got some a suitable replacement drive and I need to reload the firmware on it so I can actually use my copier.
        Cheers
        • JustManuals
          • Jan 2006
          • 9838
          Cheers
          Ah, an end user wanting to load firmware. LOL
          • gbestwick
            Well, don't laugh too hard....
            I took a 250gb hard drive, re-cut it so it had an lba indentical to an 80gb that was in the list of known models. Created an new entry in the IFT file, and loaded the firmware.
            I also wrote a utility to automatically add entries to the IFT file that fills in the correct information, formats the name and updates the model count.
            Not bad for an end user in less than 3 hours....
            • teckat
              • 16083
              • canonbundy
                • Jun 2012
                • 607
                Well ONYA, maybe you could create a version of SST that other wanting techs could use also.
                How DO you do that 'Thumbs Up' thing TechKat?
                • Canon.Tech
                  • Mar 2009
                  • 335
                  Easy!
                  • gbestwick
                    For the IFT file editor, I'd really really love to get my hands on the HDFORMAT file that are for other machines.
                    For a 40/60 GB drive they use the same information after the header, and for an 80 they use another bunch.
                    I'm wondering if there were drives issued for other machines up to 120gb before 48 bit LBA was used.
                    As for the utility, I just need to make it pretty and I will make it available for others to use!
                    Cheers
                    • teckat
                      • 16083
                      Cheers
                      good work---
                      many of the newer HDFormat.ift files are Encrypted as shown below(ex.of the iRC5180 file)
                      here is a good .pdf read on "SST HDD Not Found" message--
                      SST HDD Not Found.pdf
                      • canonbundy
                        • Jun 2012
                        • 607
                        Originally posted by Canon.Tech
                        [ATTACH=CONFIG]18519[/ATTACH]
                        Easy!
                        Love It - thanks Canon.Tech.
