Ir adv 6055 e001-110 and e001-05
  • northernlife
    • Sep 2011
    • 847
    Hi Folks. Getting an intermittent issue on one of my boxes. I've ripped apart the fuser everything looks to be ok. Happens about once every 2 weeks. I run out, clear the err and they're good for two weeks. SM states "Problem with fixing assembly" for this code. Would just like to know what can cause this code. I also checked the black connector at the rear of the fixing/feeding tray and there's no bent pins or paper caught in it.
    Thanks guys
    Jas
  • teckat
    • 16083
    Re: Ir adv 6055 e001-110 and e001-05
    Fixing Assembly high temperature error
    have u checked your wall outlet voltages ???
    especially Neutral> Ground reading ????
    is printer on a dedicated outlet-
    • northernlife
      • Sep 2011
      • 847
      It was requested to be on a dedicated line but you know these old municipal buildings. breakers are usually too overloaded for their own good. Going back with a tester today and will let you know. Thanks teck
