IRC 2880 through IRC3480
  • bartman
    • Sep 2010
    • 50
    I have not worked on these models yet. Are they good boxes? I have serviced and sold the IR3035's etc but don't know much about this color machine. Any feed back appreciated. Thx.
  • teckat
    • 16083
    Re: IRC 2880 through IRC3480
    1- buy some manuals
    2- see link below for demo copy process
    Multiple Pass
    The four colour layers are transferred to the photo-receptive drum one after another and transferred to the Color Copy paper individually with a total of four rotations of the photo-receptive drum.
    Tandem System
    This printing system contains four complete electrophotographic printing elements, one for each of the four colours. The four colour layers are transferred to the paper one after the other in a single pass.
    Transfer belt system
    In the transfer belt process the colour layers are collected on the transfer belt, which is considerably more stable than paper, and then are transferred onto the paper in a single pass.
    The basics of electrophotographic technology
    The electrophotographic process is based on the principles of positive & negative charges.
    1. A photoconductor is charged with static electricity.
    2. The photosensitive surface of the photoconductor is exposed to light, in this case in the form of a rotating laser beam.
    3. Where light hits the photoconductor, the charges are released, leaving the areas to be printed electrostatically charged.
    4. The toner (which is oppositely charged) is then attracted to the charged areas of the photoconductor.
    The photoconductor, now carrying the image to be printed, rotates at the same speed as the paper moving through the printer or copier. As the paper, which carries an opposite charge to the toner, moves under the photoconductor, the toner particles are attracted to the paper’s surface, making the image visible. In the final step the toner is fixed on to the paper with heat and pressure.
    Main Methods of Electrophotographic Technology
    The most common technology in digital colour laser printing – electrophotographic technology – has evolved over time improving both, the service and efficiency of machines.
    There are three major models of electrophotographic technology:
    link
    • northernlife
      • Sep 2011
      • 847
      I personally like them. Even more so than the newer adv c2030's. Normal drums, rollers and fusers. Only big issue I've had is the "insert black drum" message which is solved by replacing the ITB.
      • livancicm
        • Sep 2008
        • 96
        900k 4black drums 1 itb cleaning unit
        • bartman
          • Sep 2010
          • 50
          Thank you for the feedback
          • canonbundy
            • Jun 2012
            • 607
            A bit drastic changing ITB UNIT because "insert black drum" message appears, normally a bit of cleaning/vac in and around ITB & machine contacts etc should fix it.
            • lagustacat
              • Oct 2010
              • 51
              Canon IRC 2880 says replace cyan toner did replace still says relace cyan, removed toner plastic cover cleaned all sensors, still says rreplace toner, can anyone help
              • northernlife
                • Sep 2011
                • 847
                You would think it'd be that easy. Cleaning doesn't work 95% of the time for me personally.
                • teckat
                  • 16083
                  Toner level detection
                  To execute correct toner feeding, this machine has a toner feed level sensor (PS3~PS6).
                  This sensor detects the sensor flag mounted on the shaft of the feed screw.
                  This sensor flag executes reciprocating movement by the drive of the toner feed motor. It is the structure that the toner feed screw rotates and the specified amount of toner is fed to the drum unit when the sensor flag moves back and forth once.
                  At the time of the toner feeding, DC controller monitors this sensor while driving the toner feed motor. The toner
                  feed motor is stopped when the toner feeding is completed.
                  By executing this, the toner feeding is correctly implemented
                  Machine supplies toner as follows:
                  The toner coming from the hopper assembly is moved to the toner transport feed-screw A of the drum unit; then>it is moved farther by the toner transport feed-screw B while being mixed with carrier to reach the developing
                  cylinder.
                  determine if toner is packed in feed screw >Cyan dev unit port & not feeding in/ click on pic>better view
                  explanation of the toner feed route.
                  After a toner retainer is set to the main body, the toner is sent to the hopper assembly.
                  The toner sent to the hopper assembly is fed to the drum unit by the toner feed screw.
                  Toner retainers for Y, M, C and Bk. The retainer for each color is composed of toner and a stirring plate.
                  The electric load used for the feed route is the following three varieties and twelve loads.
                  - Motor: One variety, four motors used (toner feed motor)
                  - Sensor: Two varieties, eight sensors used (toner feed level sensor, toner residual level sensor)
                  M8 through M11: Toner feed motor
                  PS3 through PS6: Toner feed level sensor
                  TS1 through TS4: Toner residual level sensor (piezosensor)
                  Two kinds of toner feeding, one is 'hopper feeding' from the toner retainer to the hopper assembly and another is 'drum feeding' from the hopper assembly to the drum unit.
                  - Hopper toner refill
                  When the toner container is set in the main unit, the toner falls automatically into the hopper.
                  Also, during toner refill, the toner refill motors (M8 to M11) rotate forwards, causing the stirring plate and
                  stirring spring to rotate, making it easier for the toner to fall out.
                  - Drum unit toner refill
                  Drum feeding is executed by the toner feed motor (M8 to M11). By the negative rotation (CCW) of the toner
                  feed motor (M8 to M11), the agitating plate, the scraping spring and the toner feed screw are activated, and
                  the toner on the hopper assembly is feed to the drum unit.
                  The above operations are controlled by the DC controller. The DC controller computes the amount of toner
                  used from the ATR control results, uses this information to judge how long the toner refill motor should be
                  driven, and thus supplies the required amount of refill toner to the drum.
                  Toner absence notice -Detected by:video count
                  at 5%
                  "Black toner is low. Replacement not yet needed."
                  "Yellow toner is low. Replacement not yet needed. "
                  "Magenta toner is low. Replacement not yet needed."
                  "Cyan toner is low. Replacement not yet needed."
                  Absence of toner -Detected by: piezo sensor
                  at 0%
                  "Replace toner container. (Black)"
                  "Replace toner container. (Yellow) "
                  "Replace toner container. (Magenta) "
                  "Replace toner container. (Cyan) "
                  COPIER>FUNCTION>PART-CHK
                  MTR
                  Specify motor checking the operation.
                  Setting range: 1 to 25 (22 or above are reserves)
                  Operation method
                  1)Select the item.
                  2)Enter the motor code with the numeric keypad.
                  1: Drum ITB motor (M1)
                  2: Toner container motor (Y) (M20)
                  3: Toner container motor (M) (M21)
                  4: Toner container motor (C) (M22)
                  5: Toner container motor (Bk) (M23)
                  6: Cassette 1 pickup motor (M6)
                  7: Cassette 2 pickup motor (M7)
                  8: Cassette 3 pickup motor (M51)
                  9: Cassette 4 pickup motor (M52)
                  10: Paper deck main motor (M1D) (Paper deck)
                  11: Pre-registration motor (M8)
                  12: Registration motor (M9)
                  13: Delivery vertical path motor (M10)
                  14: Face-down delivery motor (M11)
                  15: Reserve
                  16: Horizontal registration motor (M25)
                  17: Duplexing feed motor (M26)
                  18: Developing motor (Y) (M12)
                  19: Developing motor (M) (M13)
                  20: Developing motor (C) (M14)
                  21: Developing motor (Bk) (M15)
                  3)Press [OK].
                  4)Check the operation by pressing [MTR-ON].
                  MTR-ON
                  Start the motor operation.
                  Operation method
                  Toner container motor (Y/M/C/K):
                  1)Remove the toner container, and close the front cover.
                  2)Select the item, and press [OK].
                  ON for 10 sec > OFF
                  Horizontal registration motor:
                  1)Select the item, and press [OK].
                  Start the HP search operation > After the completion of operation, automatically terminated
                  Motors other than toner container motor (Y/M/C/K) and horizontal registration motor:
                  ON for 10 sec > OFF
                  • lagustacat
                    • Oct 2010
                    • 51
                    cylinder.
                    [ATTACH=CONFIG]18665[/ATTACH]
                    [ATTACH=CONFIG]18666[/ATTACH]
                    at 5%
                    at 0%
                    MTR
                    Operation method
                    1)Select the item.
                    15: Reserve
                    3)Press [OK].
                    MTR-ON
                    Operation method
                    ON for 10 sec > OFF
                    ON for 10 sec > OFF
                    thanks for the info teckat i tried the procedure yoou recomended still same problem do you think it may be dc controller board
                    • canonbundy
                      • Jun 2012
                      • 607
                      KNOCK - KNOCK - HELLOOOO!!! Teckat has given you more info than some Canon Techs would even bother searching for, something is stopping the Unit from registering the Values which it requires, there WILL be a Sensor covered (with toner) and/or a supply tube blocked, remove the Toner Cover > the PCB and clean the sensors, you may also need to remove the Toner Hopper Assy (if there is a blockage or broken Auger) in which case you will need the Manual and i'm sure Paul can accomodate you with that.
