P PRINTS>>>>>>>>>>>>>
COPIER > Function > MISC-P > P-PRINT
MISC-P
P-PRINT=Prints service mode setting values.
Operation method
1) Select this item.
2) Press the OK key to print the setting values.
USER-PRT
Prints user mode list.
Operation method
2) Press the OK key to print the list.
**Before u perform any CLEAR for DCON/RCON/MMI/MN-CON , U need to print out settings stored in printer-be it the P-PRINT or USER-PRT both documents are important to keep on site/near printer/or with key operator
*Tech Tip-learn where your Original DCON/& RCON label settings are located/inside printer covers(different on all models)
Shown Below,this is just an example from the iRC5180 Series/ other models have similar descriptions> pays to know your imageRunners settings
MMI=Clears following user mode setting values:
- Backup data for copy operation panel (user-set values)
- Common settings backup data (user-set values)
- Backup data (except fax data) (user-set values)
The setting values are cleared after the main power switch is turned OFF/ON.
Operation method
1) Select this item, then press the OK key.
2) Turn the main power OFF/ON.
MN-CON=Clears RAM on main controller PCB's SRAM board.
- The RAM is cleared after the OK key is pressed.
- Performing this item initializes all the data on the SRAM board. In other words, file management information for the hard disk is initialized, and image data on the hard disk can no longer be read.
**Before performing this item, explain to the user that all images in the BOX will be lost, and receive permission to perform.
Operation method
1) Select COPIER > FUNCTION > MISC-P > P-PRINT to print out the service mode setting values.
2) Select this item, then press the OK key.
DC-CON=Clears DC controller PCB's RAM.
The RAM is cleared after the main power switch is turned OFF/ON.
Operation method
3) Turn the main power OFF/ON.
4) Re-Enter the data printed by the P-PRINT operation as needed.
R-CON=Use it to reset the RAM on the reader controller PCB.
Method of Operation
The RAM will not be cleared until the main power switch has been turned off and then on again.
2) Select the item, and press the OK key.
3) Turn off and then on the main power.
4) As necessary, Re-enter the settings printed out using 'PRINT'.
MISC-P
Operation method
USER-PRT
Operation method
Operation method
Operation method
Operation method
Method of Operation
