missing SCAN, MAILBOX on IR5075
  • satitjangdee
    • Jun 2011
    • 49
    HI gurus, I like this forum because there are much in depth technical knowledge.
    So, I use IR5075 but no menu button on the screen SCAN MAIL box.
    How can I add these menu?
  • vigour
    • Aug 2010
    • 1038
    Re: missing SCAN, MAILBOX on IR5075
    Canon
    • teckat
      • 16083
      Scan Tab
      Service Mode Level 2, then change OPTION > BODY > UI-RSCAN to "1"
      Mailbox Tab
      COPIER > Option > BODY > UI-BOX > 0 (Mail Box tab is unavailable)
      COPIER > Option > BODY > UI-BOX > "1" (Mail Box tab will be available)
      In older models, this option is located within Service Mode Level 1. In newer models, this option is located in Service Mode Level 2.
      also>>
      Check that in Service Mode that UI-Copy is set to "1".
      ( Copier>Option>Body> UI-Copy )
      • satitjangdee
        • Jun 2011
        • 49
        I am so apologize to you Teckat, I didn't logged-in for a long time.
        And Thank you very much that replied.
        I like your replied which so useful and technically.
        Finally you are the best friend in technical field.
        So thank.
        (Sorry, my English is not good)
        • teckat
          • 16083
          So thank.
          COLOR HAND.jpgthanks > & good luck
