IRC-4080
  • jose antonio
    • Dec 2012
    • 119
    IRC-4080
    Hi every body,
    I am new to this forum and have read very useful information.
    Right now i have copy quality problem on a canon irc-4080.
    The colors never come out correctly, the reds come like more to orange and blue more to dark purple.
    I tried to do gradation, change color settings in service mode even did a ram clear and put back all
    settings as in front door cover sheet.
    Problem still present. This machine has a H1 color pass installed, but i don't think it is calibration as
    copies on the platen glass come out the same.
    Any ideas?
    Thanks!
  • teckat
    • 16083
    Re: IRC-4080
    Originally posted by jose antonio
    Hi every body,
    Any ideas?
    Thanks!
    ?-are u using OEM Toner & Drums
    ?-what media type are u using
    ?-how old are the drums
    ?-what is the enviorment of the printer
    When performing Auto Gradation good white should paper be used--
    To achieve optimum color output use a 96 brightness or higher paper.
    did u clean the optics before glass calibration-
    did u remove old calibration from fiery - & then calibrate it with the Kodak Gray Scale or a Densitometer -
    Calibration_Process_CiRC5180.pdf
    • jose antonio
      • Dec 2012
      • 119
      Re: IRC-4080
      [ATTACH]18615[/ATTACH]
      Thanks for the pdf info!
      The machine has 40K prints total, drums & toners are genuine and ok.
      I am using normal 80gsm media 97 brightness, optics are clean.
      Could not calibrate the fiery it is on default, don't have a Gray scale or Densitometer.
      Do you know were i can order a calibration sheet?
      The local canon dealer doesn't have one.
      • teckat
        • 16083
        Re: IRC-4080
        An X-Densitometer is expensive/ but the Kodak Grey Scale is reasonable / in the packet u would only need to use the actual Grey Scale with print outs from inside the Printer tab
        Amazon.com: Kodak Color Separation Guide with Grey Scale Small Size, #Q-13: Camera & Photo
        • jose antonio
          • Dec 2012
          • 119
          Re: IRC-4080
          Thanks for the info and link!, will order today.
