Canon IR 5055 waiting to print error?????
  • landspeeder
    • Feb 2010
    • 355
    I have a IR 5055 that is displaying "waiting to print" for ever......what is the usual cause??
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: Canon IR 5055 waiting to print error?????
    Was the machine able to print before? Have you installed the right driver? Is your machine copying? Are you able to print an internal test? What is the boot version?
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • landspeeder
      • Feb 2010
      • 355
      Rachid.
      Yes it was printing...this is a new contract machine from another provider who got the heave ho....they, customer, have had it for years so I would think the driver is alright...I will be onsite tomorrow and see about a int test etc
      • teckat
        • 16083
        probably a memory issue/
        remove>clean ends>re-seat
        or-------------------------------------
        waiting to print" message
        If the System Monitor is checked, and u see a STAPLE LOADING message.
        The main cause of this issue is that the finisher has run out of staples or the staple cartridge is missing or not properly installed.
        or---------------------------------------
        "Warming Up" or "Waiting To Print"
        If the imageRUNNER indicate either or both of these messages, check to see if the Fixing temperature is rising. If it is, try disconnecting the Finisher. If the imageRUNNER will come to ready with the Finisher disconnected there may be a fault in communication with the Finisher, even though no error code is indicated.
        Check to see if the Staple Cartridge is properly seated. It has been found if the Cartridge is not fully seated in the Stapler the above symptoms may be observed.
        ??- is this when duplexing--if so>>
        When duplexing, the horizontal registration sensor PS31 and horizontal registration motor M16 detect the edge of the copy paper. If there is a drive or sensor malfunction in horizontal detection, the copier will continue to rotate and the control panel indicates "waiting to print".
        The sensor can be checked in service mode: I/O>PCON>bit 6 (0 = paper present)
        The motor can be checked in service mode: FUNCTION>PART-CHK>set MTR to 23...................
        • Netg20
          The finisher trays can cause the message. Is it intermittent? Usually you would need to reboot if this is the issue. Also maybe look at the error history to see if we have any 540,542 codes. Usually if it is in waiting to print, if you look at the tray it may be just a bit to high.
          • landspeeder
            • Feb 2010
            • 355
            The info helped yeaaaa, just to let you know the staple pack was "not" snapped into place and when it was, away it went!!!! One other thing this machine jams quite alot...I have put new feed rollers, sep pads, cleaned everything...still jams everyday...could the staple issue been a slight cause? If not what else too look for?
            • teckat
              • 16083
              Post the jam codes/
              media type
              jam on printing & copying
              locations ?/check if listed paper size on control panel is correct
              • landspeeder
                • Feb 2010
                • 355
                when it jams the lead paper is at the fuser, part of the way thru, and the paper behind it maybe 3 to 4 pages are fanned from the lead page..look like train cars. They are maybe 1-2" on the page in front as if they were not being seperated. I have changed the feed tires and sep roller which makes it go longer between jams. It is dry in the copier room so we were thinking maybe static...
                • teckat
                  • 16083
                  JAM CODES ????????????????
                  remember....if the first copy does not exit properly> everything behind it stops/jams up
                  test-----what happens when u run one single print at a time
                  • landspeeder
                    • Feb 2010
                    • 355
                    no jam codes...from what Ive seen single copies are fine.....they can also go thru a ream or two of paper without any jams .....
                    • KL568
                      _
                      • Feb 2011
                      • 324
                      Hi,
                      Any chance that 1 of drive gears sitting between fixing unit and paper transporter has a missing teeth or worn out 1-way gear?
                      Is the fixing unit good?
                      • landspeeder
                        • Feb 2010
                        • 355
                        Originally posted by KL568
                        Hi,
                        I will check that ..thanks for the idea!
                        Have a Merry Christmas!!
                        • acfife
                          • May 2012
                          • 63
                          Don't know if you are still having jamming issue?
                          It is very common on this model for the lower fuser rolller/bearings to wear out this can cause the symptoms you describe
                          the part number for this is FM2-9789-000 and comes with the bearings fitted.
                          hope this helps.
                          • techandtrader
                            • Jun 2016
                            • 335
                            hope this helps.
                            When the bearings are shot the paper might sometimes pass but will intermittently die in the fuser. no other symptoms.
                            I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
