I have a Canon iPF8300 with a message to close carriage cover I cleaned sensor cover is closeing in sensor any suggestions Thanks
Canon iPF8300
Tags: None
Re: Canon iPF8300
Below is the cover and the highlighted area where the sensor/actuator are located.
Below is a close-up of the actuator/sensor (viewed from above).
**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Re: Canon iPF8300
If you got the same error message without printheads on - that excludes that printheads are at fault.
That means that you have a electrical issue somewhere.
Start by checking in service mode (under I/O) if the sensor is working. Try with a piece of paper to see if number changes from 0 to 1.
If sensor is fine than the troubleshooting flow goes like this:
1. Check Flat Cables
2. Check Carriage board
3. Check Mainboard
Depending on your technical skills...
If you are not a technician I would strongly advice to hire one...Comment
Olenasrt
Re: Canon iPF8300
I have the same problem with my printer and the problem is not so obvious. I know it's been a long time but maybe you remember if you managed to solve the problem??? And if yes, what is the solution!
I would really appreciate if you could help me.Comment
