ir2025i
  • copicatt
    • Nov 2008
    • 361
    ir2025i
    Does anyone know if there is a original sensor detection adjustment? I have a machine that reads 11x17 90 % of the time when placing a legal pad on the glass.....they are reducing and it is screwing up the orientation.....its like that front sensor is activated......thanks. I have looked in the manual and have yet to find an adjustment
  • teckat
    • 16092
    Re: ir2025i
    Performing a "Clear All" in Service Mode may correct the issue of the wrong size paper being chosen when copying off the copyboard glass.
    The "clear all" is executed as follows: Enter Service Mode by pressing: Additional Functions, 2 then 8, Additional Functions > Scroll to Clear and press Ok > Scroll to All press Ok.
    Note: Doing an "all clear" on the imageRUNNER will result in a loss of user and network settings.
    print out the P PRINT USER SETTINGS BEFORE THIS ATTEMPT
    • copicatt
      • Nov 2008
      • 361
      Re: ir2025i
      Just tried the clear all....no change. Also swapped front detect sensor with no help. Maybe reader controller. That is what the sensor plugs into.
      • teckat
        • 16092
        Re: ir2025i
        need to check SR402 & SR403
        Original glass cover open/close sensors
        these are most important / they check the degree of angle on cover
        Copyboard cover open/close sensor (Rear: SR402)
        SR402 Photo interrupter: Detects the copyboard cover open/ close status.
        Starts detecting the original size when the copyboard cover angle is 30 deg.
        -Reader controller PCB - Controls drive of the reader unit and image processing.
        -Original sensor 3 SR406 Detects the original size (for all destinations).
        -Original sensor 4 SR407 Detects the original size (AB, INCH/AB).
        -Original sensor 5 SR408 Detects the original size (INCH/A)
        -Reader motor M401 Pulse motor: Controls drive of the carriage.
        -Reader heater*1 - Prevents condensation inside the original glass.
        -Original sensor 1 SR404 Detects the original size (AB, INCH/A, INCH/AB).
        -Original sensor 2 SR405 Detects the original size (AB, A, INCH/AB)
        -Contact image sensor (CIS) - Uses LEDs for indirect exposure (LED + Photo-conductor)
        -CISHP sensor SR401 Photo interrupter: Detects the CIS position.
        -Copyboard cover open/close sensor SR403 Finishes detecting the original size when the copyboard cover angle is 5 deg.
        *1 Service parts setting
