IPC7010 -E194-0061 / 0071
  • twinax
    • 82
    Hello guys,
    We have an error code E194 -0061 and 0071 on IPC 7010, we are unable to do the auto correction color alignement which give E194. color on page are mixed (black into magenta).
    The PG type 5 are printed properly.
    On CP-Print Dens-Y, dens-M are at 0, also P-B-P-x are at 0 too.
    Did you already got this problem?
    Do you have an idea how to manage it?
    Kind regards,
    Twinax
    Remember Murphy's Law.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: IPC7010 -E194-0061 / 0071
    Did you check ITB life time?
    NG-replace ITB
    OK- execute the ITB gloss recovery mode (COPIER > FUNCTION > HV-TR >ITB-GLS).
    -Execute auto color displacement correction control (COPIER > FUNCTION > MISC-P > AT-IMG-X)
    Before do anything first clean sensor face of color registration patch sensor.
    • twinax
      • 82
      Thank you,
      ITB and color sensor has been replaced without success !
      Is there possible to check the patch on ITB?
      I think that the patch have problem and can not be read!
      What did you do in that case?
      Thank you
      • zoraldinho
        • Mar 2008
        • 5015
        E194 061,071.pdf
        Autogradation Suspended” message.pdf
        • twinax
          • 82
          Hello Zolraldinho,
          Many thanks for your help,
          After investigation on field I saw that the black color was too early on print (PG Type 10) and cause the error code E194.
          The problem has been solved by a DC-Con clear, and put all values manually.
          I think that during the maintenance the DC-Con PCB got some ESD from vaccum cleaner.
          Your information are always useful,
          Happy new year for you and your familly.
          Twinax
          • zoraldinho
            • Mar 2008
            • 5015
            Any time.
            Happy holidays
