imageRUNNER ADVANCE C2020/ C2030
A Change Has Been Made to the Remedy for an E748-2010
Publication describes a change that has been made to the remedy in resolving an E748-2010.
While E748-2010 is defined as a FLASH PCB error in the Service Manual, it may also occur due to a HDD
failure in the products of the series shown below. Therefore, the descriptions of the error details and remedy
will be changed for the products of the following series.
[Target Product Series]
imageRUNNER ADVANCE 8105 PRO / 8095 PRO / 8085 PRO Series
imageRUNNER ADVANCE 6075 / 6065 / 6055 Series
imageRUNNER ADVANCE 4051 / 4045 / 4035 / 4025 Series
imageRUNNER ADVANCE C2030 / C2025 / C2020 Series
When an E748-2010 occurs, perform the remedy according to the following descriptions.
Title == Flash PCB error / HDD error
Detection Description== Flash PCB error has occurred or the HDD cannot be recognized.
Remedy=
1. After turning OFF the main power, disconnect the HDD interface connector (*) of the Main Controller PCB 2 and turn ON the main power.
2. If the Error Code E748-2010 remains unchanged, it means a Flash PCB error has occurred so replace the Flash PCB and re-install the system using the Service Support Tool or USB Flash Drive.
3. If it changes to another error code such as E602, refer to the remedy of the applicable code.
(*) HDD Interface Connector
J12 (Main Controller PCB 2)
imageRUNNER ADVANCE 8105 PRO / 8095PRO / 8085 PRO Series
imageRUNNER ADVANCE C2030 / C2025 / C2020 Series J102 (Main Controller PCB 2)
Remedy=
