Measures to Minimize Dark Spots
see pdf------------
Dark spots between 0.5mm and 2 mm in diameter may appear on solid images when printing in low
temperature environments. The symptom is more prominent with cyan and magenta toner and it has
been reported by customers who use coated paper.
Products Affected: -----------Serial Numbers Affected:
imageRUNNER ADVANCE C7055 --All Serial Numbers Affected
imageRUNNER ADVANCE C7065 --All Serial Numbers Affected
imageRUNNER ADVANCE C9065S PRO --All Serial Numbers Affected
imageRUNNER ADVANCE C9075S PRO --All Serial Numbers Affected
imageRUNNER ADVANCE C9065 PRO --All Serial Numbers Affected
imageRUNNER ADVANCE C9075 PRO --All Serial Numbers Affected
see pdf------------
