CANON IR 3100C
  • ernesto
    • Oct 2011
    • 430
    CANON IR 3100C
    Hi,
    Does Anyone know why there are black toner everywhere? black developer is gone, isn t it ?
    the photocopier has 520.000 in black copies.
    I hope to hear from you.
    all the best
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: CANON IR 3100C
    Originally posted by ernesto
    Hi,
    all the best
    Hello,
    Replace black dev unit : FM2-1751-120000
    Rachid
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • Gamut
      • Jul 2008
      • 216
      Re: CANON IR 3100C
      This is a classic fault with those piles of SH*TE
      The customer has fitted the Black toner cartridge poorly and the machine has then spun toner around the turret area!!!!!
      Pull out drum, all dev units, Laser assembly and anything else affected, vac out m/c, check Black toner latching and re-assemble.
      Then wait for next time a toner cartridge is fitted. (at least you will know what to do by then).
      • teckat
        • 16083
        Re: CANON IR 3100C
        Follow the correct procedures for after replacing the black developing unit
        1. Execute the following service mode item:
        Copier > Function > INSTALL > STIR-K
        Copier > FUnction > INSTALL > SPLY-K
        2. thereafter, check to see that the value has been initialized to "0": COPIER > COUNTER > MISC > DV-UNT-K
        3. Execute Full Adjust of auto gradation correction in Additional Function.
        Note:
        DV-UNT-K indicates the number of sheets that have moved past through the developing unit. (The count is retained by the DC controller PCB.)
        Do not reset the reading or enter a new reading unless you have done the action indicated. Otherwise , the machine may have to operate on incorrect image density, producing foggy output or damaging the drum (by carrier particles), requiring you to replace the developing unit (Bk), and initialize the reading.
        The machines ATR control consists in the correction of the toner supply amount based on the target density and the patch image density it measures at specific times. It corrects the target density for individual colors, and it makes correction for Bk based on the cumulative number of images made.
        • Canon.Tech
          • Mar 2009
          • 335
          Re: CANON IR 3100C
          Oh such joy when this happens!
          Allow a few hours to clean up, & you WILL need a vacum cleaner!
          • ernesto
            • Oct 2011
            • 430
            Re: CANON IR 3100C
            • ernesto
              • Oct 2011
              • 430
              Re: CANON IR 3100C
              Note:
              • teckat
                • 16083
                Re: CANON IR 3100C
                YES
                DV-UNT-K Developing unit passing sheet count (The count is stored in DC controller PCB.)
                - If the development unit (Bk) is replaced, clear the count.
                - If the DC controller PCB is replaced, input the value stored in the PCB before its replacement.
                <How to input>
                1) Select the item to highlight.
                2) Select the count [1], highlight it, and input the value stored in the PCB
                before its replacement using ten-key.
                3) Press OK button.
                Do not clear or input the value except the cases described above.
                If do it, fogging might occur due to the failure of image density or drum might be damaged due to the carrier. If the value is cleared or newly input by mistake, clear the count after replacing the developing unit (Bk).
                • ernesto
                  • Oct 2011
                  • 430
                  Re: CANON IR 3100C
                  YES
                  <How to input>
                  3) Press OK button.
                  Thanks a lot, Mr Teckat
