Hello
I'm having a problem and I'm hoping somebody could help..
I have an irc 3580i with y1 finisher, and when i want to staple copies (not booklet!) it only staples the first sheet, the second one or the third are not correctly alligned back into the stapler..
And when i want to make more than one copies(ex. 5 times to staple 3 sheets), the problem will occur only on the first copy(first 3 sheet).Other copies will be stapled fine.
I heard form someone that it's probably not rollers fault, becouse collate option works fine.
If anybody has experience with this problem, or any suggestion, I would be most grateful.
Best regards
Tim
Best regards
Tim
