I removed the spring loaded black handle that unlatches the drum unit tray. I caused the error code seen above. can someone tell me how to re-install it correctly .Thank's John
Canon IRC3180i / Error code E 000 990-0000
Re: Canon IRC3180i / Error code E 000 990-0000
This model dont have a handle.Drum is fixed with two screws. Dont tell me you broke this one too!If it ain't broke, don't fix it
A picture is worth a thousand words -
It is the same copier.Canon IRC 3080i. My appologies for the mis-statement of the model number. Just a civil answer would suffice. In order to get to the drum unit assy. to slide out towards you. You have to remove the (2) screws and then turn a black spring loaded release handle located on the right. What I'm asking for is how to reinstall the handle and reload the spring inside the handle to the correct tension.Comment
There is no procedure to disassemble a handle.If you decide to fix something without knowledge to save some money keep in mind to call a technician at the and.If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
If your trying to tick somebody off learn how to spell, "end" not "and" asshole.Comment
u mean the handle to pull out the process unit
502-SCREW
29-HANDLE, LOCK, RIGHT
26-SPRING, COMPRESSION
28-SPRING, TORSION
22-BUSHING
501-WASHER,COP
25-STOPPER, HANDLE**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Sorry for the time lapse to your response. Yes, It's the highlighted diagram you sent. I need to re-align the shaft , that the handle turns and at the same time install the handle while loading the tension on 1 of the 2 springs that go inside the handle. Thank's for your helpComment
Sorry for the time lapse to your response. Yes, It's the highlighted diagram you sent. I need to re-align the shaft , that the handle turns and at the same time install the handle while loading the tension on 1 of the 2 springs that go inside the handle. Thank's for your help**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
