How remove toner cart on IRAC 5051
  • benerin
    • Dec 2011
    • 59
    [Misc] How remove toner cart on IRAC 5051
    Hello everybidy.. have a good day..
    I have some question regarding on how to remove toner cart even it's not yet finished. I have other machine (same model) at are not working anymore but still have toner in cartridge I want to take that toner and to transfer on other machine which same model..
    Thank you inadvance..
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: How remove toner cart on IRAC 5051
    This is procedure for Canon trained tech.If you are not,call one.
    In Service Mode Level 2 make the following change. COPIER>OPTION>DSPLY-SW> T-CRG-SW. Set T-CRG-SW to a 1.
    Exit Service Mode and perform the following:
    In User Mode, enter SETTINGS AND REGISTRATION> ADJUSTMENTS/MAINTENANCE> MAINTENANCE> REPLACE SPECIFIED TONER.
      The instructions for removing the toner bottle manually if the machine is dead, should be in your service manual.
      • JustManuals
        • Jan 2006
        • 9838
        If you can't remove the toner cartridge which is the most basic of all functions, you should call a trained authorized Canon technician.
        HtH
        Paul@justmanuals.com
        Yes, I have the service manual if you want to buy it, email me.
        • benerin
          • Dec 2011
          • 59
          Thank you Mr. Zoraldinho,
          You right sir, I'm not trained Canon technician. prevouisly i'm Sharp & Xerox technician technician for almost 20 years now, only this time i"m started this brand,
          Again Sir thank very much.. Hopefully next time you can help again, hehehehehe
          • zoraldinho
            • Mar 2008
            • 5018
            Depends on you.
