How to Set adf Canon ir2535.
  • makmee
    • May 2012
    • 24
    Hi all,
    I've seen some of these problems.
    Adf copy of the document is missing.
    Placed on the document glass full.
    Thanks for your help.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: How to Set adf Canon ir2535.
    More info please! Did ADF detect document? How do you mean missing copy?
    Are you a tech?
    • makmee
      • May 2012
      • 24
      Are you a tech?
      Some parts are missing.
      on adf
      on Platen Glass.
      Still do not.
      I like this
      • zoraldinho
        • Mar 2008
        • 5007
        Check ADF adjustments and paper feed rollers.Read PDF....
        adf adjust.pdf
        • arielcanon
          • Mar 2012
          • 106
          what's your document size to be copied on ADF? sometime we need to set on service mode for different size for copying from ADF. e.g: switch from A4 to FLSC
          Learning never ends..
          Never give up, where there is a wheel there is a way..
          • semsros
            • 12
            Dear All
            This is looking like my problem, My machine canon ir2535 v120, when I copy document A4 or A3 size on ADF it is cutting like Letter size, if I copy document A4 size on platen is ok.
            please give me some idea to fix it
            thanks you
            • roho
              • Mar 2009
              • 844
              Originally posted by makmee
              Hi all,
              If it's happening when using the glass then adjust the height of the dadf. I've had a few of these, replaced original sensors on the first one to no avail. The height needs to be adjusted and the dadf squared, then the original sensors under the copyboard glass will read correctly. This is the only model I've needed to do this on, worked on at least three I can remember.
              • dame1933
                • Aug 2017
                • 2
                Originally posted by semsros
                Dear All
                thanks you
                DID anybody find a way to fix this problem? I still had this trouble
                • teckat
                  • 16083
                  Service Mode>SCAN>SCAN READER>OPTION>BODY>SENS CNF = 1
                  Power cycle machine.
                  To make the value of SENS-CNF stick after the Copier is rebooted, the following needs to be set in service mode.
                  SCAN > SCAN SW > SW06 > Bit2 to 1
                  Also, to enable the correct paper selection, change the following setting of the paper size
                  group.
                  SYSTEM > SYSTEM Numeric > 057 to 3 for inch configuration
                  1: AB configuration
                  2: A configuration
                  3: Inch configuration
                  4: AB / Inch configuration
                  • charles
                    • Jul 2017
                    • 8
                    Dear All
                    thanks you
                    pls reset the copier by the services mode
                    • dame1933
                      • Aug 2017
                      • 2
                      group.
                      1: AB configuration
                      2: A configuration
                      thanks very much bro, its really work
                      • teckat
                        • 16083
                        cartoon-business-man-02.jpgwelcome
