CANON IR5055 E0225-0001
  • hamdyyassin
    • 84
    My copier canon ir5055 has an error e00225-0001 , I changed the scanning lamp but still have same error.
    thanks for help.
  • teckat
    • 16083
    Re: CANON IR5055 E0225-0001
    thanks for help.
    does the lamp light and try and perform an intensity adjustment
    then go to error---this can caused by an excessively soiled white plate.
    white plate can be found of the bottom left side of the copy glass/u may need to replace the copy glass
    does scanning lamp come on before the machine codes out.
    if so try > replacing the CCD unit
    verify that System Software version 30.05 or higher is installed in the Copier.
