Recently we bought a canon IR7095 to replace our old IR 105, but when we attached the finisher the machine can't detect it. can somebody help me how to program it.
Practice makes perfect
If you want something done right, you have to do it yourself
EXAMPLES
The finisher functions do not appear available on the display of the imageRUNNER.
confirm the following steps:
1) Check if the finisher version is listed in service mode COPIER>DISPLAY>SORTER
2) Check if the finisher is registered in service mode COPIER>OPTION>ACCPST-D
3) Check your ARCNET cables for T-Conections and Terminators on the imageRUNNER and the Finisher.
If your display does not show any version, and your ACCPST-D shows the finisher is attached, try the following steps:
1) Set the value listed in the ACCPST-D to "00", press OK
2) Exit service mode, power off the imageRUNNER, and power off the Finisher.
3) Disconnect the ARCNET cable from the imageRUNNER only.
4) Power on ONLY the imageRUNNER.
5) Check COPIER>OPTION>ACCPST-D (At this point the finisher should no longer be listed)
6) Power off the imageRUNNER
7) Confirm BOTH the imageRUNNER and the finisher have T-Connectors and terminators.
8) Power on the finisher, then power on the imageRUNNER (Note: Power on sequence is important.)
9) Check COPIER>OPTION>ACCPST-D The value should be listed as "01" for the finisher. If the ACCPST-D lists the finisher as "00", try setting to "01", then press OK. (Note: If you have other ARCNET devices attached they will be listed, too, assuming you have connected the ARCNET cables with T-Connectors and have terminated the last device.)
10) Check COPIER>DISPLAY>SORTER Now you should see the finisher listed and the finisher functions available.
Thanks in advance...
From Canon------------------
Finisher is Not Recognized By the Machine The Finisher is not recognized by the Machine.
The Arcnet connections have been checked; the T Connectors and Terminators are installed on both the Copier and Finisher. When the rear cover of the Finisher was removed, it was noticed that there were no LED's lit on the Finisher Controller. Next, the supply voltages were checked at the Finisher Controller and there was no voltage into the Controller. Upon further investigation, it was found that the Power Supply also was not outputting any DC Voltage. The AC Supply voltage to the Power Supply was tested, and 0VAC was found at Connector J1.
Solution :
When the Finisher is plugged into the back of the Copier, the AC supply voltage for the Finisher comes from the AC Driver. The AC Driver was tested at connector J2 and 0VAC was found. Upon further investigation, the fuse on the AC Driver was removed and checked for continuity. In this case, the fuse was bad and was replaced to resolve the issue.
Note:
As stated above, the fuse was bad and replacing the fuse resolved the issue. In some cases, the AC Driver may need to be replaced.
Check if the braided ground strap on the finisher had been disconnected when removing the rear cover. Upon connecting the ground strap, powering up the finisher and then the host machine, the finisher was again available.
