Canon ir3245 Restart required to clear jam !
  • deaneop
    • May 2012
    • 9
    Hi,
    I have a machine in a customer that has had half a dozen visits due to having to restart to clear any finisher jams machine is fitted with an inner finisher s1. Jams from trays or deck clear no problem.
    Steps taken so far:
    Firmware upgrade
    Finisher controller pcb replaced
    Dc controller replaced
    Anybody got any idea's ?
  • Brian8506
    • 1665
    Re: Canon ir3245 Restart required to clear jam !
    If you open front cover does display tell you its open? I've seen where interlock, which is flimsy, gets bent enough so when the front sorter cover is put back on it actuates the switch and copier never knows when the door is opened and closed.
    • deaneop
      • May 2012
      • 9
      I'm almost certain the door switch is fine as I have been opening in to cause the machine to jam, have ordered a new main interface cable and if that dont work i will use my trust hammer
      • Chameleon
        • Nov 2011
        • 200
        Since you replaced the PCB's related to the issue I would try the firmware again. Instead of holding down 2 & 8, go into download mode from service mode Copier>Function>System>Download. I'm not 100% sure but I think the options like Fax or Finisher don't get flashed when you do firmware from the 28 boot, only entering download mode from service mode. Also, select FORCE write in SST.
        The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Check the flag sensors switches on the pick up assy. They sometimes get stuck. Or a bad sensor that not resetting its self. Look in service mode, identify what the jam code is and what sensor.
          • kiwitech
            • Oct 2012
            • 29
            i'm thinking door switch. this could be not only main door but any door including paper cassette. you can view each switch operation in service mode i/o
