Canon C1030if losing scan connection
  • Cosmo Monkey
    [Error Code] Canon C1030if losing scan connection
    Hello,
    This is my first post, so be gentle. I have a Canon C1030 setup to scan to computers within our network (workgroup not domain). I am losing connection to the only one computer with an #806 error. My smb settings are correct, (I believe) and this is only an intermittent problem. I can reboot the computer and it will reconnect. I have replaced all cables involved. When connection is lost, I can still print.
    Thank you for reading,
    Cosmo
  • teckat
    • 16083
    Re: Canon C1030if losing scan connection
    Originally posted by Cosmo Monkey
    Hello,
    Cosmo
    May help
    Believe u can increase data size to 99MB for sending
    Send Data Size Limit 0 to 99MB, in 1MB unit (3MB*) *is the standard setting
    under>Additional Functions key
    System Management Set. > Communication Settings>E-mail/I-Fax Settings>Send Data Size Limit
    #806 [SMB] Sending to a shared folder
    Cause
    -Incorrect username or password was specified when
    sending to the shared folder.
    -Incorrect destination was specified when sending to a shared folder.
    Remedy
    -Check and verify that the username and password are correct.
    -Check and verify that shared folder destination is correct.
    #806 [FTP] Sending to FTP server
    Cause
    sending to the FTP Server.
    -Incorrect destination was specified when sending an FTP server.
    Remedy
    -Check and verify that FTP server is correct.
    #806 [SMTP] Sending to e-mail server
    Cause
    sending to the E-mail/I-fax Server.
    Remedy
    -Check and verify that E-mail/I-fax server destination is correct.
    -Incorrect destination was specified when sending an E- mail/Ifax server.
    Notes:
    Please use Microsoft Outlook Express (DO NOT USE OUTLOOK) to test, verify and confirm the correct requirements for the E-mail server that the customer is trying to use to send E-mail. You can bring up Microsoft Outlook Express by clicking START > RUN then
    type MSIMN and click OK. Then create an E-mail account using the information that was provided to you and try to send an email from MS Outlook Express.
    • Cosmo Monkey
      Originally posted by teckat
      May help
      Cause
      Remedy
      Cause
      Remedy
      Cause
      Remedy
      Notes:
      Thank you, I will try that this morning. Not sure if that will correct the problems because as you listed the #806 error seems to refer to permissions. I can print from the computer, just not scan to it.
      Again, thank you for your suggestions. Will post results at end of day.
      Cosmo
