IR-2535 (E000)
  • zero2004
    • Jul 2025
    [Error Code] IR-2535 (E000)
    Hi every one
    an error code appear suddenly on canon ir-2535 copier (E000), can you tell me the problem with this error, and how can overcome it and the way to reset the error.
    Thanks for your cooperation
  • teckat
    • 16083
    Re: IR-2535 (E000)
    Originally posted by zero2004
    Hi every one
    imageRUNNER 2525 / 2530 / 2535 / 2545
    How to clear E000, E001, E002 and E003.
    1-Enter service mode by pressing additional functions than 2 than 8 and then Additional Functions.
    #SSSW will be displayed.
    2-Use the right arrow and scroll to #CLEAR then press OK.
    3-Use the right arrow and scroll to ENGINE then press OK.
    ERRCLR will be displayed then press OK.
    4-Then power cycle the machine.
    Service Mode : ADDITIONAL FUNCTIONS>2 KEY>8 KEY> ADDITIONAL FUNCTIONS>#CLEAR>ENGINE>ERRCLR.
    Note: This mode should be used to clear all Fixing related Error Codes.
    If this does not resolve the error code. / u need to call for service or if u are a tech--pull out the fix unit to inspect
    • zero2004
      Re: IR-2535 (E000)
      First of all, thanks for your assistance, can you tell me the cause of this error, and which unit i must inspect
      • teckat
        • 16083
        Re: IR-2535 (E000)
        best to get a manual to understand your product
        this is usually an issue with the Fixing Film Unit
        E000 0001 = Fixing temperature abnormal rise
        Description =The temperature detected by the main thermistor does not rise to the specified value during startup control.
        Remedy =
        1.Go through the following to clear the error: CLEAR >
        ENGIN > ERRCLR; and then turn OFF and then ON the
        power.
        2.Check connection of the Connectors (Thermistor Connector and AC Connector).
        3.Replace the Fixing Main Thermistor (Film Unit).
        4.Replace the Fixing Assembly.
        5.Replace the DC Controller PCB (PCB4).
        see pdf.
        Film Unit.pdf
        click on pic> better view
        • zero2004
          Re: IR-2535 (E000)
          Remedy =
          power.
          see pdf.
          [ATTACH]18956[/ATTACH]
          [ATTACH=CONFIG]18955[/ATTACH]
          thank you very much
          • Rachid.Akli
            • Oct 2011
            • 595
            Re: IR-2535 (E000)
            Hi to all,
            If clearing the error code fixes the issue, it could be explained by the fact that when the power source drops to less than 10% of its nominal value (220V in our region), the fixing temperature will take more time to reach the required value. This could result in E000 error code. If the error couldn't be cleared, start by replacing the fixing film resistance assembly. and don't forget to clear the error again as explained above.
            Rachid
            "Find a job you love and you’ll never have to work a day in your life." Nagy's father
            • zero2004
              Re: IR-2535 (E000)
              Thanks for all help
              Where can I buy Fixing Assembly and how much it cost
              • canonbundy
                • Jun 2012
                • 607
                Re: IR-2535 (E000)
                Thanks for all help
                Where are you Located? Judging by your questions I assume you are not a Canon Tech, as far as I am aware there are no 'after market' consumable/parts available for this model therefore you will need to contact your local Canon Dealer.
                • teckat
                  • 16083
                  Re: IR-2535 (E000)
                  FM4-3363-000 1 FIXING ASSEMBLY iR2545/2535 Series 120V
                  [DP]
                  FM3-9302-000 1 FIXING ASSEMBLY iR2545/2535 Series 230V
                  [DP]
                  FM4-3364-000 1 FIXING FILM ASSEMBLY 120V
                  H1,H2,TH1,TH2,TH3
                  FM3-9303-000 1 FIXING FILM ASSEMBLY 230V
                  H1,H2,TH1,TH2,TH3
                  FC9-8974-000 1 ROLLER, PRESSURE
                  iR2545/2535/2530/2525/2520 Series
                  • zoraldinho
                    teacher-guide-expert-guru
                    • Mar 2008
                    • 5007
                    Re: IR-2535 (E000)
                    Check system version!
                    System WLaa-63-01
                    Modification of E000 error that occurs in a low temperature environment upon the completion of print job.
                    • zero2004
                      Re: IR-2535 (E000)
                      Thanks for all
                      • DAG COPIERS & COMPUTERS
                        • Oct 2010
                        • 860
                        Re: IR-2535 (E000)
                        Who said 'there's no after market' consumables/parts already available for this model? The Chinese & Indian manufacturer are 'leaving no stone un-turned', in their quest to dominate the tech industry. Here,(In the 3rd world), we already have duplicated parts/consumable for this model of machine on the market! I recently replaced the fuser film only, and the Drum cylinder & c/blade (They all come as separate components) for an iR 2530, Manufacturer..... a certain 'KIYO' company. Non-OEMs but they work well......at least as of now!
                        • teckat
                          • 16083
                          Re: IR-2535 (E000)
