After market HDD for Canon's
  • Eddie
    • Jun 2009
    • 31
    Has any one had any success with After market HDD's.
    Canon is so expensive. I have tried some after market ones but its hard to find 80G HDD's.
    right now canon wants $350 for a new HDD. it is cheaper to by old laptop computers with 80GB HDD and us it.
  • teckat
    • 16092
    Re: After market HDD for Canon's
    not all take 80gb HDD
    many aftermarket HDD's work> trick is knowing what to use>
    newer models have the HDFormat.ift file encrypted so u can't view the HDD options
    On some older models the HDFormat.ift file is viewable for the HDDDescriptor so it can be modified
    see pdf---
    • CThurman
      • Jan 2013
      • 15
      The dealer I work for has ordered some refurbished hdds in the past with considerable cost savings. Prob about half price or so of new. I think we got them either from hytec repair services in florida or nationwide repair services of KC, mo. The downfall is they dont last as long as oem part. If you install this in an older machine such as canon 3300 series 4570 series etc prob would be beneficial considering machine upgrade is coming soon. So if you only need the machine to last another year or two might be worth the gamble. For details check out hytecrepair.com or nwrsinc.com. Good luck!
      • Copierdocisleofman
        Senior Technician
        • Aug 2009
        • 86
        I had to put a new HDD in a Canon 2380i recently but everything I tried didn't work.
        I have an old Ricoh 3260 in the office with 4 80GB HDD's in and one of these worked in it.
        So the answer is find a second hand Ricoh 3260 and take the HDD's out!! Simple. ;-)
        Thanks for the info on editiing the HDD format program.
        • Brian8506
          • 1655
          Nationwide in Kansas is very reasonable and I haven't had any problems with their hdd's
          • teckat
            • 16092
            these usually work in the Color image runners/ if u can find
            IC35L040AVER07-0
            IC35L040AVVA07-0
            IC35L060AVER07-0
            IC35L080AVVA07-0
            QUANTUM FIREBALLP AS40.0
            QUANTUM FIREBALLP AS60.0
            FUJITSU MPG3409AH E
            Maxtor 4D040H2
            SAMSUNG SP4002H
            MAXTOR 6L040J2
            MAXTOR 6L060J3
            IC35L060AVV207-0
            IC35L060AVV207-0
            SAMSUNG SP0411N
            HDS722540VLAT20
            ST340014A
            HDS728040PLAT20
            Hitachi HDS721680PLAT80
            WDC WD800BB-22JHC0
            • Eddie
              • Jun 2009
              • 31
              thanks for all the help and suggestions.
              • campy
                • May 2012
                • 315
                We also use Nationwide with no problems.
