Canon EFI Fiery - NX Series
  • farst_eddy
    • Jan 2013
    • 9
    [Misc] Canon EFI Fiery - NX Series
    Anyone out there able to help on PS-NX800 (same box as PS-NX3000).
    Only shows BIOS on boot. H/Disk appears OK (mounted on PC).
    Was perfectly OK - booted up to idle fine - shut down & turned on again four weeks later - then this.
    Surely not M/Board??
  • teckat
    • 16083
    Re: Canon EFI Fiery - NX Series
    ColorPASS-Z800 server is also known as PS-NX800 in some markets
    u will probably need to re-load the firmware
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      I'm not a Cannon guy, But I am a Fiery guy and I agree with Teckcat !!!!
      Mystic Crystal Revelations
      • farst_eddy
        • Jan 2013
        • 9
        A little embarrased actually. I do not have any technical info on this RIP, so spent yesterday afternoon reading up on PS-NX3000 (for 3200 series), as unit appears virtually the same. Managed to deduce that my employee that cleaned the unit had left the CPU connector (J2) unplugged - problem over.
        I do not have System Software for this unit - and have had problems in past trying to find a reliable way to 'clone' the Fiery drives. Issues relating to drive size mismatches possibly. If it helps anyone to know then I can clone a drive using Acronis (usually a larger drive which Acronis 'expands' onto), then Fiery will boot OK, but will not successfully perform a 'system restore'. Am thinking to generate an 'ISO' image of a drive and try that.
        If anyone has got either/both NX800 system software, and a Fiery Diagnostic software (for NX 600 upwards), then I am happy to share whatever I have that may be useful (but only up to approx. 2008).
        p.s. Am I the only person left running CLC900!!! - Anyone impressed?? -
        p.p.s. Have Canon produced a machine that comes close to 1100 quality/versatility(materials)??
        • teckat
          • 16083
          I never want to ever see a CLC900 & it's 80 + tech pubs on issues
          and that includes the CLC1100 series and it's tech pubs on issues>
          quality/versatility(materials) that does not describe a printer of this nature when customers who purchased it originally abused it's recommended usage.
          i would charge 500.00 per hour to service this thing>if forced to (if i ever need milk money)
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5018
            bad experience??
            • farst_eddy
              • Jan 2013
              • 9
              Hi,
              Thanks for the reply, but am not entirely understanding your answer.
              Pls - am new - have I posted on the wrong forum catergory??
              Ref:-Canon CLC (900 or 1100 series) - I was asking if Canon have a more recent colour machine that can be used in a wide range of uses.
              I am running up to 350gsm pulp card, and even textured card up to 300gsm, (even d/sided), along with a range of other substrates (heat transfer papers, vinyls etc).
              The reason I ask is because I have not heard of any Canon model that comes close (Yes - speed is damn slow, but versatility is my main issue)
              I email old friends that are still engaged in servicing in UK, and concensus seems to be that 3200/3260/4040/5151 models are not necessarily any better, although obviously faster.
              (Servicing is not too much problem - I still understand the basics - getting a sheet of paper from one end to the other with toner on it).
              Maybe you guys can put me right?
              Do I consider Konica/Minolta bizhubs?
              p.s. Where I am is somewhere that Canon have not landed yet - honest
              • teckat
                • 16083
                Originally posted by zoraldinho
                bad experience??
                1-Print Shops
                2-Customers who thought this was a printing pressCard Stock
                3-Runs dirty( especially when in poor location or pushed against a wall
                4-Transfer sheet
                5-Fuser unit re-build, OIL Spills, Customer adding XEROX OIL / overheating covers
                6-Customers slamming hopper closed after each jam
                7-Developer changes
                8-E020's/E061/E071-2/E804
                9-Pick-up units
                10-Cassettes
                need more
