c3220 printout second copy is dirt
  • pc123321
    • Dec 2012
    • 103
    i have a canon c3220 if only printout one copy is ok
    if printout 5 copies , after printoput one copy , the rest output is dirt
    is there anyone could give me the advice how to solve the problem
    thanks
    jason
  • vigour
    • Aug 2010
    • 1038
    Re: c3220 printout second copy is dirt
    Post some pictuures.
    Sounds like your cleaning blade.
    • pc123321
      • Dec 2012
      • 103
      left hand side
      this 11 x 17 glossy paper 100lb text
      cleaning blade replace recently
      • SCREWTAPE
        East Coast Imaging
        • 3396
        You say flushing new york. That's queens?
        • pc123321
          • Dec 2012
          • 103
          yes
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Are you a tech?
            I'm a certified canon tech.
            I work in the city. Need help!
            • Canon.Tech
              • Mar 2009
              • 335
              From your sample it looks ike your magenta drum needs replacing, but take up screwtapes offer there maybe other items worn etc.
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 5015
                thanks
                jason
                One and only solution is new drums.
                • pc123321
                  • Dec 2012
                  • 103
                  i check the c3220 4 drum life : enter service mode , additional 2,8 additional key
                  copier--display---misc the result :
                  yellow : 1,
                  magenta :28
                  cyan : 23
                  black : 51
                  the magenta drum is remanufactured drum
                  charger roller worn out or this is gereric drum
                  for this information drum still new but not real canon product ??
                  or buy canon genuine drum ---
                  most people try to find acceptable price for their drum ! ! !
                    • 16083
                    yellow : 1,
                    magenta :28
                    cyan : 23
                    black : 51
                    Run some PG 10's
                    & some single color PG 5's
                    do u know how to run these test prints ????
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      yellow : 1,
                      magenta :28
                      cyan : 23
                      black : 51
                      As I said to you before, I can help plus help you get some OEM drums for a good price if needed. I'm flexible!!!
                      I maintain a number of clients in your area. And I could support you with whatever you need. I will give you my contact in private message.
                      Check your notifications.
                      • SCREWTAPE
                        East Coast Imaging
                        • 3396
                        yellow : 1,
                        magenta :28
                        cyan : 23
                        black : 51
                        All you will get is responses here. I'm certified and trained on this model for the last ten years. I was one of the first one's who was trained on this model in the east coast at Jamesburg, NJ. Don't pass.
                        • pc123321
                          • Dec 2012
                          • 103
                          thanks all the canon tech, Zoraldinho,teckat,canon tech and screwtape
                          all your guys already known that customer buy third party drum or toner , they will get the return ,,lose money and get trouble for their canon copier, use the oem drum and toner----
                          if the problem isolate ,---drum and toner ---t/d ratio everything is clear,
                          as you said , i dig a hole , and jump it -----that's interesting -------------am i right
                          today i install new oem magenta drum ---------nothing wrong
                          • pc123321
                            • Dec 2012
                            • 103
