I'm a newbie to the Canon line so maybe this will be something easy. I have a IR8095 with a D1 Finisher. The machine is intermittently jamming with a Jam Code of 112F. In the manual the description for this code is super vague (Finisher Error Avoidance Jam). Which to my understanding it's shutting the machine down to avoid an error code. I can make 100 copies of 1 original and it will jam at some point in that run. Anything under 100 seems to not jam. If I make copies with multiple originals seems to run perfect. Which is probably just a huge coincidence but figured I'd throw that in.
When it does jam, they are always in the same spot. 1 about half out the finisher exit, 1 at S101(Sensor right before it enters the hole punch area) 1 in the fuser, 1 going towards the imaging area and 1 right behind it coming out of the cassette.
I checked error logs and it didn't show any errors for today. It did have one yesterday and 3 days prior that both pertain to the finisher. E0583-8002 & E0542-8001. Any ideas would be appreciated, I don't have access to tech pubs at the moment...working on that and hopefully will by tomorrow. Thanks in advance.
