Canon IR 2016i - DADF-P1 problem
  • trshi
    • Jan 2013
    • 11
    Hello,
    When I copy a letter on the glass the print is perfect. However, when I print from the media tray (DADF-P1) I have a line that prints down the page. I have attached a test page for you to see what I am referring too. I have tried all suggestions on http://www.copytechnet.com/forums/ca...ice-guide.html but that did not work. Any suggestions? I have purchased a canon iR 2016i service manual but I may need to purchase a DADF-P1 service manual if need be.
    Thanks for you help in advance,
    Trshi
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: Canon IR 2016i - DADF-P1 problem
    Originally posted by trshi
    Hello,
    Trshi
    Hello sir,
    Clean or replace the small reading glass.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
        Turn the green cog/wheel inside the dadf cover and watch the white roller underneath turn, probably a block of muck somewhere.
        • trshi
          • Jan 2013
          • 11
          Thank you! That worked!
