We have a 3220 with a blank screen, the power light is the only thing lit. Copier warms up but no display i swapped control panel and same problem. I was thinking of replacing the hard drive any thoughts?. Thanks
irc 3220 control panel issue
Re: irc 3220 control panel issue
Quick ??? if printer warms up >can u send a network print from PC to it for printing ???
also check your outlet for correct voltages
Ensure that the voltage between the neutral and ground poles is 1/2 a volt or less. If the voltage is higher than 1/2 a volt, an electrician needs to look at and correct the outlet. See the diagram below for check points.
First Try cleaning and re-seating all the boards and dimms associated with the Main Controller.
Check the connection between the Sub-Main Controller (J1303) and the Main Controller (J1209) to see if they are seated correctly.
see pdf--attached below
Board Cleaning_TP07 094[1].pdf (245.1 KB)
There are many reasons the LCD screen on the C3200 is blank but this scenario gives a hint.
The Main Controller PCB has an LED101 which is ON during normal operation.
When you experience a blank LCD screen, inspect the Main Controller PCB LED101, if the LED is OFF, then replace the SRAM PCB (FG3-3669-000) which is mounted on the Sub Main Controller PCB.
There could be a problem with the memory, a blown fuse on the fuse pcb, a defective control panel, boot rom, memory, etc...Attached Files**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
I disconnected the imagePASS, powered up the copier, and the LCD panel came back to life.
Then powered off, reconnected the imagePASS, and powered back up.
Probably a bad connection corrected by the operation, but it is still working.Comment
I had the exact same problem and the fuse pcb ended up fixing it. Mine would go black, and would usually come back on after a main power cycle. It would only work for a day or two until it did it again. unfortunately the fuse pcb wasnt the first thing I replaced! I tried both main controllers, control panel, memory etc before fuse pcb. I hope it fixes yours also. Good luck and let us know how this one turns out please. DC FUSE PCB FG3-2337-000Comment
